| | | Forums66 Topics128,113 Posts1,056,277 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2012 Posts: 73 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2012 Posts: 73 | I'm tearing the head off my '62 235 (burnt valve). While I have it apart, I thought I may as well change out the cracked exhaust manifold.
I've heard you should change out the intake along with the exhaust manifold so that you end up with a paired set to help prevent future exhaust manifold cracking.
Advice would be much appreciated. Thanks!
Glen | | | | | Joined: Mar 2009 Posts: 124 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 124 | what i did, was have the manifold mating surfaces machined flat and used new gaskets. you also have to tickle the manifolds into place. this system worked for me and left no leaks. | | | | | Joined: Sep 2010 Posts: 695 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 695 | True, the gaskets can be a little forgiving if the manifold mating surfaces aren't square. I think the problem you could have, is if your old manifolds have been remachined at some point. A remachined intake with a fresh new exhaust may be difficult to fit as a set since they fit in two places... against the head in one vertical plane, and to each other in a horizontal plane. If you tightened the bolts to the head first, you may have a gap in the horizontal. When you torque those bolts, you would then be putting stress on the castings. This could eventually cause a failure... like a cracked manifold. From this, I can see why it might be preferred to replace both parts. I liked the "tickling" term. It means to me, that you tighten gradually, the vertical plane and the horizontal plane similar to the bolts on a head... in a type of sequence. Then at least, you'd be averaging the unsquare error to both planes. You'd still have stress on the castings though. If it were in my budget and to insure I had no problems, I reckon I'd replace both parts with new. Just thoughts... Jerry | | | | | Joined: Feb 2012 Posts: 73 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2012 Posts: 73 | Thanks guys. I'm half contemplating just living with the noise. Wrecker here wants $200 for one.
| | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Pick up the used one, put it on, don't tighten it up, not all the way just enough to get the Intake and Exhaust both close then tighten the two together, take them off still attached together (Tight so they can't move) and to the machinist and have him plane them down together...
| | | | | Joined: Feb 2012 Posts: 73 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2012 Posts: 73 | I like that idea. Thanks! (If I can find one for under $200!) | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | depending on where and how bad the crack is you could have it repaired by having it spray welded. i have had a few things repaired that way with success. | | |
