6 members (frogfarmer, klhansen, Bill Hanlon, 2-Ton, Wally / Montana, JoergK.), 127 guests, and 1 robot.
Topics128,192
Posts1,057,354
Members48,469
#870666 07/30/2012 3:56 PM
Anyone know where to pick up a set? Or am I stuck having to find somewhere to get them relined?
1953 1 ton panel
I scoured the internet last year to find a good set, with little luck. Finally had my local brake guy reline them and make new pads. Ended up being cheaper than trying to find used and running the risk of still having to have them redone.
Bruce
I had mine redone and I am very happy with them. There was no problem installing them and they work great.
1951 1 Ton Completed
Anyone know a place that relines brake shoes in the Seattle WA area?
1953 1 ton panel
NAPA has shoes to fit your truck (UP299R).
They also have return springs 80163 (set of 4) and the adjuster spring @ the bottom that holds the 2 shoes together 80518 (also a set of 4).
New, made in USA wheel cylinders are available from Dorman as W18010. Same for both sides. I bought mine on Amazon.com.
The 14" x 2-1/2" Bendix brake was used up into the 80's in the Chevy truck line.
Looking for a company advertising "industrial frictions" will usually get you to a place that does relining.
'38 Chevy 1-1/2 ton
'49 Chevy 1/2 ton
'54 Chevy 6400 2 ton
'55.2 GMC 3/4 ton
'56 GMC 1-ton
No Room Left in Shop
I sent mine to jim carter, When I got them back they were bonded and not rivited, But they work fine.
49 chevy 1-ton. It is a work in progress but it's getting close. 49 1 Ton Pics
Moderated by  Dusty53
