4 members (DoubleB, greenie-reddy, 41appletruck, Oswald), 85 guests, and 1 robot.
Topics128,091
Posts1,056,038
Members48,433
#8703 05/12/2002 6:47 AM
Junior Member
Junior Member
I have a Toyota Land Cruiser with a chev 250 (obviously not original). I'm running a mono-jet carb that wistles at idle and when driving at low RPM. I just bought the rig not too long ago, so I haven't messed with it too much. I haven't been able to locate any vaccum leaks and can't find any loose bolts. Any ideas?
I'm not too worried about it, because it runs great, it just sounds a little odd.
I've learned a lot from all you guys. Thanks!
Steve
#8704 05/12/2002 7:10 AM
.Sounds about normal for every inline-6 cylinder with 1-barrel carb I have heard without an air-cleaner.If you put a vacuum guage on it and you get a steady 17inHg + of reading at a warm idle, it is nothing to be concerned about.
#8705 05/12/2002 7:34 PM
The '74 Nova 250 6 cylinder that I had with the 1 Barrel Monojet also whistled under certain conditions. I could usually make it do it when I messed with the idle mixture. Certain speeds and mixture combintations led to the whistle. I just richened it a tad to eliminate it . I cannot remember if you could hear the whistle with the air cleaneri installed, but definintly without it! Great car, great engine- very reliable and smooth.
#8706 05/13/2002 12:21 PM
Thats a vacuum leak look for a lose carb or missing hose
if it dosen't need fixed, break it
#8707 05/18/2002 1:55 AM
Steve,
If there are no vacuum leaks, I'd say it's normal carb aspiration going on, particularly if there's a small aftermerket air cleaner; the Rochester "B" on my old 235 Chevy stovebolts, particularly the ones with the small "truck air cleaner" (no silencer) whistled like hell, particularly at part throttle; I've grown fond of that noise- driving an AD Chevy would not be the same without it! wink
Frank McMullen
1941 Chevy dump truck
1949 GMC 100 pick-up
1954 Chevy 3600 pick-up
1955.1 4400 dump truck
1941 De Soto & other MoPars
1928 Model A F**D Special Coupe
#8708 05/18/2002 4:53 PM
the type and style air cleaner will have a lot to do with the amount of venturi whistle you can hear. The original air cleaners are a lot of metal and break the sound fairly well, but the more popular replacement filters with exposed filter will transmit the venturi whistle almost as if there is no air cleaner on it at all.
