8 members (JW51, Woodcmiami, Gdads51, dt235sd, MickeyP, HandyAndy, k2handyman, 1 invisible),
58
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,699 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2011 Posts: 47 | Hey guys, I have a question. What should my compression be on my 216? The engine is a 1953, all stock.
Sure appreciate any info.
Thanks. | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | My google search brought up this... AD specs
| | | | | Joined: Mar 2011 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2011 Posts: 47 | Thanks, That is some great info. Thanks again | | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | That chart seems to be a little optomistic on compressiion pressure. As long as the pressures don't vary a lot, compression from 80-100 PSI should be acceptable. A maximum variation of about 7%-10% from one cylinder to another is considered to be acceptable. Be sure you're cranking the engine with a well-charged battery, with all the spark plugs removed and the throttle blocked wide open. I've seen stovebolt engines run pretty smoothly with compression as low as 40-50 PSI as long as all the cylinders were within a few pounds of each other. Jerry
| | | | | Joined: Mar 2011 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2011 Posts: 47 | Jerry, Thanks for the info. You see, the reason I ask is my engine idles roughly. It kinda has what feels like a stumble. I've checked everything as far as I know. The vac holes to the riser are clear, carb was rebuilt. good compression, over 100, no smoke, clean fuel filter, new fuel pump, new air filter, point, plugs, condenser, coil. I can't seem to figure it out. I appreciate any advice. Thanks. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | one thing to check is your idle mixture adjustment on your carb. ...click... steps 1 - 4 also idling adjustment ...click... steps 1 - 5... using a vacuum gauge | | |
