0 members (),
93
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#87030 01/17/2005 12:45 AM | Joined: Jan 2005 Posts: 364 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 364 | I've got a '47 Chev. Loadmaster, I can't get any spark. I've repalaced all the obvious "tune-up" parts (points, cond., cap, rotor, coil) and still nothing. I checked my voltage at the coil with ign. switch on, I have 7.5 volts, while cranking the engine over, I have 5.5 volts. Is my starter drawing too much current and not leaving enough for the ignition? (I did this test w/plugs removed to reduce compression and reduce strain on the starter)
Keith If it were easy they'd have grade schoolers doing it! | | |
#87031 01/17/2005 12:48 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | That sounds pretty typical, but check your battery cables for corrosion. 6V systems need twice the current for starters so I like to use 2/0 or 4/0 battery cables instead of the ususal #4 or #2 12V battery cables you get at the auto parts store. This greatly reduces the voltage drop across the cables.
You may want to do the spark plugs too, when I first got my truck it wouldn't start until I replaced them and then it fired right up.
#87032 01/17/2005 1:06 AM | Joined: Jan 2005 Posts: 364 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 364 | Thanks I'll try the battery cables and see what happens, I forgot to mention plugs, wires, and starter motor brushes are new, maybe cables are the the last thing on the list. This is my first time in the forum, I've been on the site many times looking in. I've found your own experience combined with the experience of others with the same interests is better that some old shop manual.
#87033 01/17/2005 8:09 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Did you check the voltage at the - side of the coil when the points are closed? It should be close to zero. When they are open, it should be about battery voltage. If not, you will never get a spark.
#87034 01/18/2005 12:28 AM | Joined: Jan 2005 Posts: 364 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 364 | Thanks 4.O.T.F., my eyes must be gettin' bad, I could've sworn the points were closing all the way but 1 check w/the voltmeter proved otherwise! Don't you hate it when you beat yourself up over something as simple as that? Thanks again.
#87035 01/18/2005 2:43 AM | Joined: May 2000 Posts: 1 Member | | Member Joined: May 2000 Posts: 1 | Sounds like you got your problem solved. One other thing, for those that have similar problems. With the ground cable from the battery going to the frame, and the frame acting as the current path, the old rivets in the frame build up corrosion and make high resistance connections, dropping voltage. On my '53 (6 V) it got so bad I had a special ground cable made up at the local battery store. It has two cables coming out of the battery connection. One, the short one, goes to the original frame connection. The other cable connects directly to the top bolt that holds the starter to the engine. Before my cranking voltage was about 5.2 volts. After it was about 5.9 volts. Made a big difference in cranking speed.
Ed | | |
#87036 01/19/2005 3:19 PM | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | Pakrat,
is your 47 an art deco or an AD? | | |
#87037 01/20/2005 4:46 AM | Joined: Jan 2005 Posts: 364 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 364 | '46IP, it's an AD, saw your pics of your 46, looks like a nice solid project.
