1 members (SandraD),
56
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2009 Posts: 134 Wrench Fetcher | | Wrench Fetcher Joined: May 2009 Posts: 134 | question,,, i have a good 248 block and I just want to de glaze the cylinders with a flex hone... anyone know the best grit for these old blocks... 1940's block
I like fixing stuff.
| | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | Most of the dingleberry hones I've used were in the 300-400 grit ranges. They're definitely not used for resizing cylinders, just setting up a crosshatch pattern for ring seating. Be absolutely sure to do a hot water and detergent scrubdown with a stiff-bristle brush, followed by a HOT water rinse. The small scratches can trap enough hone grit to wear out a set of rings in just a few miles. I learned that the hard way with a fresh re-ring job on a trip from California to Tennessee. By the end of a 2500-mile run, the engine was using 3 quarts of oil to a tank of gas, and the rings were worn to less than half their original thickness! Jerry
