1 members (texczech), 51 guests, and 2 robots.
Topics128,024
Posts1,055,395
Members48,422
Hey guys, I have a question. What should my compression be on my 216? The engine is a 1953, all stock.
Sure appreciate any info.
Thanks.
My google search brought up this...
AD specs
Give me ambiguity
or give me something else
Thanks, That is some great info. Thanks again
H Online: Content
That chart seems to be a little optomistic on compressiion pressure. As long as the pressures don't vary a lot, compression from 80-100 PSI should be acceptable. A maximum variation of about 7%-10% from one cylinder to another is considered to be acceptable. Be sure you're cranking the engine with a well-charged battery, with all the spark plugs removed and the throttle blocked wide open. I've seen stovebolt engines run pretty smoothly with compression as low as 40-50 PSI as long as all the cylinders were within a few pounds of each other.
Jerry, Thanks for the info. You see, the reason I ask is my engine idles roughly. It kinda has what feels like a stumble. I've checked everything as far as I know. The vac holes to the riser are clear, carb was rebuilt. good compression, over 100, no smoke, clean fuel filter, new fuel pump, new air filter, point, plugs, condenser, coil. I can't seem to figure it out. I appreciate any advice. Thanks.
one thing to check is your idle mixture adjustment on your carb.
...click...
steps 1 - 4
also idling adjustment
...click...
steps 1 - 5... using a vacuum gauge
