| | | Forums66 Topics128,052 Posts1,055,770 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#86978 03/27/2005 6:38 PM | Joined: Oct 2000 Posts: 244 'Bolter | | 'Bolter Joined: Oct 2000 Posts: 244 | Does anyone know of a way to test a Flasher outside of the car to see if it is good. I'm attempting to wire my 1953 GMC with a 7 wire signal flasher and want to test the flasher unit to make sure the one I have is still good. | | |
#86979 03/27/2005 6:47 PM | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | Is it 12v? If so, just buy a new one and replace. They're cheap, and at worst, you have a spare for when it does burn out. | | |
#86980 03/27/2005 8:45 PM | Joined: Oct 2000 Posts: 244 'Bolter | | 'Bolter Joined: Oct 2000 Posts: 244 | Oops! I forgot to mention that it is a 3 prong flasher marked with "X", "L", and "P" terminals. | | |
#86981 03/27/2005 10:42 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | X is the hot lead. L goes to the light. You may need more load than just a test light. P is the pilot if you use only one indicator for both sides.  They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#86982 03/27/2005 11:04 PM | Joined: Feb 2004 Posts: 29,772 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,772 | Use a 12 volt sealed beam headlight as a load, and apply power to the X terminal. The P terminal doesn't necessarily need a pilot light attached, it will flash with or without that one connected. 3-terminal flashers are hopelessly out of date. Just get a heavy-duty 2-pin flasher and it will flash up to 6 lights in parallel. Jerry
#86983 03/27/2005 11:32 PM | Joined: Mar 2001 Posts: 629 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 629 | put a good looking woman in front of him.
Tim Sheridan 1947 First Series Chevy 1/2-Ton"Liberty Series" - "Art Deco" - Whatever you'd like to call it. In the Gallery | | |
#86984 03/27/2005 11:41 PM | Joined: Oct 2000 Posts: 244 'Bolter | | 'Bolter Joined: Oct 2000 Posts: 244 | HotRod,
The wiring diagram that came with the turn signal unit showed a flasher with 3 prongs. How would I wire it with only a 2 prong flasher ... any tricks? This is a 7 wire turn signal unit 12 volt. | | |
#86985 03/28/2005 4:06 AM | Joined: Feb 2004 Posts: 29,772 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,772 | Does it have the indicator bulb on the end of the signal stalk? If so, the wire that goes to the indicator gets wired to both sides of the output, with diodes to keep the signal from backing up to the opposite side than is selected. If you've got the arrow-shaped indicator lights on both sides of the dash, just wire them into the front turn signal circuit, so they don't come on with the brake lights. In that case, don't connect the bulb in the stalk to anything. Jerry
#86986 03/29/2005 6:15 AM | Joined: May 2000 Posts: 69 Wrench Fetcher | | Wrench Fetcher Joined: May 2000 Posts: 69 | I posted this some time ago:
This is for the Chieftain 7 wire turn signals.
Yellow to left front turn signal. Green to right front turn signal Brown to right rear turn signal Orange to left rear turn signal
There are two posts on the brake/stoplight switch. One is "hot". The other is not. Red wire from turn signal switch goes to the brake switch post that is not hot.
You should be left with a black and a blue wire. If your flasher is 2 pole, twist the black wire and blue wire together, and fasten both to the post marked "L". If your flasher is three-pole, fasten the black wire to "L", the blue wire to to "P". Whether you have a 2 pole or 3 pole flasher, fasten your hot wire from the ignition to the flasher pole marked "X" | | |
#86987 03/29/2005 8:38 PM | Joined: Oct 2000 Posts: 244 'Bolter | | 'Bolter Joined: Oct 2000 Posts: 244 | Thanks for all the great information. I'll work on it this weekend and let you know how well it goes. | | |
#86988 04/02/2005 12:57 AM | Joined: Jan 2005 Posts: 95 Member | | Member Joined: Jan 2005 Posts: 95 | Texaholic, Thanks for the directions for the Chieftan turn signal switch. I finally got it wired tonight. Whoopeee!! Lights at last!! | | |
