6 members (Woodcmiami, MNSmith, Otto Skorzeny, Guitplayer, Lostbuthaulinass, Gray_Ghost), 61 guests, and 1 robot.
Topics128,057
Posts1,055,812
#86978 03/27/2005 6:38 PM
Does anyone know of a way to test a Flasher outside of the car to see if it is good. I'm attempting to wire my 1953 GMC with a 7 wire signal flasher and want to test the flasher unit to make sure the one I have is still good.
#86979 03/27/2005 6:47 PM
Is it 12v? If so, just buy a new one and replace. They're cheap, and at worst, you have a spare for when it does burn out.
1954 GMC De Luxe COE
#86980 03/27/2005 8:45 PM
Oops! I forgot to mention that it is a 3 prong flasher marked with "X", "L", and "P" terminals.
#86981 03/27/2005 10:42 PM
Riding in the Passing Lane
X is the hot lead. L goes to the light. You may need more load than just a test light. P is the pilot if you use only one indicator for both sides. smile
1972 Chevy c10 Cheyenne Super
#86982 03/27/2005 11:04 PM
Use a 12 volt sealed beam headlight as a load, and apply power to the X terminal. The P terminal doesn't necessarily need a pilot light attached, it will flash with or without that one connected. 3-terminal flashers are hopelessly out of date. Just get a heavy-duty 2-pin flasher and it will flash up to 6 lights in parallel.
#86983 03/27/2005 11:32 PM
put a good looking woman in front of him.
Tim Sheridan
1947 First Series Chevy 1/2-Ton
"Liberty Series" - "Art Deco" - Whatever you'd like to call it.
#86984 03/27/2005 11:41 PM
HotRod,
The wiring diagram that came with the turn signal unit showed a flasher with 3 prongs. How would I wire it with only a 2 prong flasher ... any tricks? This is a 7 wire turn signal unit 12 volt.
#86985 03/28/2005 4:06 AM
Does it have the indicator bulb on the end of the signal stalk? If so, the wire that goes to the indicator gets wired to both sides of the output, with diodes to keep the signal from backing up to the opposite side than is selected. If you've got the arrow-shaped indicator lights on both sides of the dash, just wire them into the front turn signal circuit, so they don't come on with the brake lights. In that case, don't connect the bulb in the stalk to anything.
#86986 03/29/2005 6:15 AM
I posted this some time ago:
This is for the Chieftain 7 wire turn signals.
Yellow to left front turn signal.
Green to right front turn signal
Brown to right rear turn signal
Orange to left rear turn signal
There are two posts on the brake/stoplight switch. One is "hot". The other is not. Red wire from turn signal switch goes to the brake switch post that is not hot.
You should be left with a black and a blue wire. If your flasher is 2 pole, twist the black wire and blue wire together, and fasten both to the post marked "L".
If your flasher is three-pole, fasten the black wire to "L", the blue wire to to "P". Whether you have a 2 pole or 3 pole flasher, fasten your hot wire from the ignition to the flasher pole marked "X"
#86987 03/29/2005 8:38 PM
Thanks for all the great information. I'll work on it this weekend and let you know how well it goes.
#86988 04/02/2005 12:57 AM
Texaholic, Thanks for the directions for the Chieftan turn signal switch. I finally got it wired tonight. Whoopeee!! Lights at last!!
