3 members (KEVINSKI, Bill Hanlon, JW51), 229 guests, and 1 robot.
Topics128,101
Posts1,056,180
Members48,436
Page 70 of 177 1 2 … 68 69 70 71 72 … 176 177
Big Bolt Forum Co-moderator
Originally Posted by BLUEMEANIE
Changed the oil, installed a new accelerator return spring and smacked the side mirror off backing into my garage. Wah wahhhh. Hopefully this isn't the beginning of 7yrs bad luck.
On the upside, I'm taking this opportunity to add the passenger side mirror and arm while I'm doing the driver side.
I don't think so, since it's a rear view mirror. It just means you might of had some bad luck in the past.
1948 Chevy 2-Ton
I just cracked the passenger windshield while trying to install it.
Now that's something to cry about. Sorry buddy...
~Jim
I like the way you think! Hopefully this wraps up a bad streak I've been having!
I just got the back glass installed on my '53 3100. No cracks this time. If I knew you guys were comfortable with explicit language I'd describe how difficult this has been.
Marcus,this is an issue that comes up time and time again,you're certainly not alone!
Glad you got 'er done though.
I'm quite sure if we posted a glossary of the profanity some of us used in the process we could invent a new language! lol.
More pix on Flickr.
Removed the gas tank, ordered up a por-15 kit for it. Removed one of the carbs, cleaned up and resealed it.
1953 1 ton panel
Usually that job is finished up with a cold brew...or several cold brews.
~Jim
Since I had broken the passenger windshield the day before, and could tear up an anvil in a sand pile, I was happy to get the back glass in. Though during the installation I prayed, cussed, threw tools, even had to walk away and watch Andy Griffith for a while.
Body bolts removed from Panel - ready to prop up on stands for work on frame... Engine & tranny out of donor vehicle...
Larry Bear
55.5 Chevy 3100 Panel
Just about finished with the stereo.
Robert C.
I'm a Genius in the making.
1950 3600
Well done Robert C.
I don't believe I heard any Merle Haggard there Buddy.
~Jim
http://coreys46chevytruck.shutterfly.com/ this is a site for my ole fumblim 46 chevy in progress if anyone gives a hoot
Nice job Robert!
More pix on Flickr.
Of course we give a hoot Corey!
Looks like you're making good progress.
More pix on Flickr.
back yard wrench turner
Now that I have insurance and a license plate I took my 1st legal test drive today.
It still drives like a 1938 Chevy farm truck smile
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
Slick. Nice job. It even gives me ideas!
What did I get done? ...I dun got towed. Twice in two days but it was a blast driving her while it lasted. Wrenching was fun too, as always. Got a full day of it lined up for tomorrow.
I thought the illegal test drives in your photo album looked like fun, driving that chassis down the street.
1948 Chevy 2-Ton
Cleaned out 15year old oil in the pan. It looked like snot water. Disassembled the carb and cleaned throughly.
1950 Chevy 3600
Authorized Pest
Authorized Pest
"Snot water." That's a very good word picture.
YUCK!
~ Peggy M
1949 Chevrolet 3804
I installed my tie rod and modern ends. Removed the balls from the steering arms. I took a different route than most. I cut the ball off the arm and then ground the ball end down, thinking the other end was swedged at the factory. I then pressed the balls out from the ball end and they came out easily. No drilling, or even grinding into my arms. I am not sure if that makes sense or not. Pictures in my bucket.
http://s960.photobucket.com/albums/ae90/scrambler45/
On my 65 1/2T stepside: Counting yesterday and today, removed the gas tank and cleaned the entire fuel system. Reinstalled the tank and fuel lines, gapped the plugs and adjusted the timing by ear, but need to get a light on it soon. Gonna restore the gas tank sometime soon using a kit that removes rust and seals it.
My 12 yr old son and I pulled the 216 out of the truck. Big step in 3-4 year project. Going to replace 3-speed with T5 trans but keeping the foot starter so going to use original bellhousing. Did a quick fit of T5 pressure plate off a Camaro T5 but holes a bit off. plenty of time to solve that one.
http://s848.photobucket.com/albums/ab41/malibu67/1951%20Chevy%20Truck/
1951 Chevy 3100
Nice job with the stereo. Would like to look a little closer at how do did that. Again well done.
1949 Chevy 4400 216
Saturday I got the front brakes and bearings back together, inspected the rears and figured out I need shoes, hub seals and wheel cylinders. Put her back on the ground with the new steel wheels and fresh tires from craigslist I picked up first thing in the morning. Today I cleaned out carburator #2, flushed out the fuel lines and started the POR-15 process inside the gas tank. Just gotta wait for the tank to be super dry and this week hopefully I can pour in the sealer.
1953 1 ton panel
Change front tires, mounted new 9.00x20 tires on GMC 454-30, cleaned rims and painted them.
Matched-up rear tires/wheels and remounted them, put new tires on front rims. 6.5x20 Motor Wheel rims.
Yesterday, I bought another complete 52-53 GMC 454-30 for parts donor truck.
Dance like no one is watching,
Sing like no one is listening,
Love like you've never been hurt.
1948 GMC FC101 1/2t Pickup w/270 and SM420
1948 GMC FC253 1t Factory 80"x9' Flatbed Dually
1948 Chevy COE 2 Ton 8'x15' Flatbed
1950 GMC 354-24 2 Ton 8'X12' Flatbed w/Dump Hoist
1953 GMC 454-30 3 Ton 8'x14' Flatbed w/Dump Hoist
1953 GMC 454-30 3 Ton Cab and Chassis
1942 Clarkator 6 MILL-44 Heavy Aircraft Tug
1942 Ford (9N) Moto Tug with 1/2 yard Loader
1947 Oliver OC3 HG-42 Tract-Crawler Bull Dozier w/6' Blade
Figured out why she left me stranded twice ... don't add lead additive and marvel to a half empty tank. I figured it'd be ok if I added it and drove to the gas station. Both times I only made it around a mile. She ran fine around town till it all mixed. Got a 5gal can, filled her up and she ran fine.
Also took the opportunity to replace a hacked off carb stud so I could get the proper spacer under the carburetor.
On Saturday I finally got the exterior visor painted and installed.
http://farm8.staticflickr.com/7112/7676714742_90201d1ce9_b.jpg
I wondered about those pictures on Flickr...
On the bright side the visor looks great!
More pix on Flickr.
Fitted the front fender beading in place,got the hood fitting a little better,still not 100% yet,kinda tricky on your own.
I'm still chasing an air leak in the front suspension RH airbag,I think it's at the top of the bag which means stripping the front right hub assembly apart again.......bwaaaah!
More pix on Flickr.
My 16 year old Daughter and I re-wired the tail/brake lights. She soldered all the connections and incased the wires in braided metal loom..
a great day
1950 Chevy 3600
Instagram/Olbluechevytruck
on Classic trucks:
http://rides.classictrucks.com/ride/1085750/olblue/1950/chevrolet/c20/
Went out to the garage, tools in hand. Then the 105 degree heat hit me square in the face. I then retreated back to my air-conditioned man cave for the rest of the day. A smart man knows when to sit back down.
~Jim
a great day
Sounds like you've got a young 'boltress' in the making!
More pix on Flickr.
Remounted headlight buckets with new gaskets and wire pig tails, already had 12v headlights. Finished tightening all the lug nuts for new tires and remounted rims.
Need to finish new wiring, got a job for truck hauling fire wood and logs for a tree cutter.
My trucks have to earn their way.;)
added a rear "dome light" at the rear of my panel. Use a LED with an off on switch. Works nice.....after I replace a blown fuse where I let the wire ground out!!
Also painted the Impala steering wheel I'm going to use. Will put the clear coat on it tomorrow.
Love your new icon Alvin...
~Jim
Thanks BigChevy. The grandkids love it!
Well, I decided to put the tachometer in the panel today that a bolter friend donated to me. What a guy!! Works great.
Pic???
Where did you mount it?
~Jim
cleaned my truck for a show on saturday
Big Chevy, its a small tach and I mounted it under the dash where the E-Brake bracket is suppose to go. I installed and tiltedit up. Its out of the way and I can glance at it anytime I need to. I'm leaving for Wilmington at noon tomorrow but will get a pic.....soon.
I plan to use the e-brake handle out of a dodge Colt and mount it on the right of the drivers bucket seat.
...Oh, and I sanded the '58 Impala steering wheel with some 2000 and reshot the color.....will clear coat tomorrow or saturday...or Monday. Got to go see father in law this weekend.
