| | | Forums66 Topics128,136 Posts1,056,426 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#86909 06/07/2004 2:02 PM | Joined: Jan 2002 Posts: 175 Member | | Member Joined: Jan 2002 Posts: 175 | Do you cut this grommet after you run the wire through the firewall or thread all the wires through it first. My old one was split but the new replacement is intact | | |
#86910 06/07/2004 2:53 PM | Joined: Feb 2004 Posts: 29,818 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,818 | It will work either way. If you're doing a complete harness replacement, leave it uncut, fit it into the firewall, thread the new harness through, and go about your rewiring. Cutting the grommet just makes it possible to replace it without disconnecting the whole harness. A little brake fluid on the grommet will make it easier to install, and it won't hurt the rubber like oil would. Jerry
#86911 06/07/2004 2:54 PM | Joined: Mar 2002 Posts: 553 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 553 | I would try not to cut it and run all the wires through it after it's in. You're gonna half to run all the wires through anyways so you might as well have the grommet in uncut. | | |
#86912 06/07/2004 3:59 PM | Joined: Jun 2003 Posts: 331 Member | | Member Joined: Jun 2003 Posts: 331 | I don't think it is a good idea to use brake fluid for lube it will eat the paint | | |
#86913 06/07/2004 4:41 PM | Joined: Jan 2002 Posts: 175 Member | | Member Joined: Jan 2002 Posts: 175 | I agree. I use silicone or armorall | | |
