4 members (stlcardinalsguy, RLB, 2-Ton, Leo), 127 guests, and 1 robot.
Topics128,136
Posts1,056,427
Members48,441
#86909 06/07/2004 2:02 PM
Do you cut this grommet after you run the wire through the firewall or thread all the wires through it first. My old one was split but the new replacement is intact
It will work either way. If you're doing a complete harness replacement, leave it uncut, fit it into the firewall, thread the new harness through, and go about your rewiring. Cutting the grommet just makes it possible to replace it without disconnecting the whole harness. A little brake fluid on the grommet will make it easier to install, and it won't hurt the rubber like oil would.
I would try not to cut it and run all the wires through it after it's in. You're gonna half to run all the wires through anyways so you might as well have the grommet in uncut.
I don't think it is a good idea to use brake fluid for lube it will eat the paint
I agree. I use silicone or armorall
