0 members (),
83
Mod | | | Forums66 Topics128,081 Posts1,056,318 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 44 New Guy | | New Guy Joined: Jun 2012 Posts: 44 | Where can I buy new front parking light assemblies as my son's on his '53GMC are shot. Thanks | | | | | Joined: Mar 2012 Posts: 240 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 240 | A lot of folks use "Classic Parts" or "Jim Carter's" for items like that. I've heard others mention "Chevys of the 40's" and "Patricks". "Brothers", "The Filling Station", and "LMC" get mentioned a lot. There are a lot of sources out there, and this list is hardly exhaustive.
Most of us probably have favorites, but these are mentioned often.
Welcome to the Stovebolt and have fun with the '53.
1947 3100 Advanced Design
Never, never, never, never give up. - Churchill | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Bdammers47 is assuming '53 GMC parking lights are reproduced. I don't believe they are. Nearly every Chevy part is reproduced but us GMC guys sometimes have to settle for used unless we can luck into NOS items. Keep your eyes on Ebay & etc. In the mean time sign up at http://www.oldgmctrucks.com/ also. | | | | | Joined: Apr 2001 Posts: 268 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 268 | Lens, Lens Gaskets and Housing/fender gaskets are available.
But not the housing themselves.
Guide B50, I believe.
Dance like no one is watching, Sing like no one is listening, Love like you've never been hurt.
1948 GMC FC101 1/2t Pickup w/270 and SM420 1948 GMC FC253 1t Factory 80"x9' Flatbed Dually 1948 Chevy COE 2 Ton 8'x15' Flatbed 1950 GMC 354-24 2 Ton 8'X12' Flatbed w/Dump Hoist 1953 GMC 454-30 3 Ton 8'x14' Flatbed w/Dump Hoist 1953 GMC 454-30 3 Ton Cab and Chassis 1942 Clarkator 6 MILL-44 Heavy Aircraft Tug 1942 Ford (9N) Moto Tug with 1/2 yard Loader 1947 Oliver OC3 HG-42 Tract-Crawler Bull Dozier w/6' Blade
| | | | | Joined: Jun 2012 Posts: 44 New Guy | | New Guy Joined: Jun 2012 Posts: 44 | Thank you, I guess I will look for used parts. | | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | Nearly every Chevy part is reproduced but us GMC guys sometimes have to settle for used unless we can luck into NOS items. This surprised me when I was looking to use them as signal lights on my Chev. | | | | | Joined: May 2007 Posts: 289 Shop Shark | | Shop Shark Joined: May 2007 Posts: 289 | I am in the process of restoring the original front parking lights on my '52 GMC. They are Guide B-50's. If you do a Google search for that you will come up for some originals for sale. From that I learned they were also used for back up lights on Cadillac but from the pictures I saw the lens looks different than on mine. The lens are reproduced but not the base assembly. | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | Information on the 1947-1953 parking lights The differences in the lenses are: BACK UP LENS (B50 HOUSING - B29 LENS) ECCENTRIC PRISMATIC RINGS FROM BOTTOM TO TOP - ALSO HAVE TAPERED GASKETS BETWEEN LIGHT HOUSING TO FENDER GMC PARK LENS (B50 HOUSING - F45 LENS) - ECCENTRIC PRISMATIC RINGS STOP AT 2/3 MARK AND HAVE A MAGNIFYING TYPE CLEAR GLASS TO THE TOP. ALSO HAVE FLAT GASKET BETWEEN LIGHT HOUSING TO FENDER I believe that this information is correct, if not someone will provide the correct information. | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Place a add in the parts wanted section,I bet somebody has a set for you.
Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I gave up trying to find and pay for real GMC parking lights. I used new repro Chevy lights for for a later year and they look quite similar. | | | | | Joined: Jun 2012 Posts: 44 New Guy | | New Guy Joined: Jun 2012 Posts: 44 | | | | | | Joined: Mar 2012 Posts: 240 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 240 | Cleits: You are correct, I spoke too soon.
My apologies.
Never, never, never, never give up. - Churchill | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I believe the ones I used are for 55 to 57 Chev trucks. They are in the Jim carter catalog. Parking Lights 55 to 57 By the way it appears his online catalog is improved and actually works now! | | | | | Joined: Nov 2009 Posts: 639 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 639 | I used back-up lights from an early 50s Chevy car for my '53 GMC. I rarely see those on ebay and NEVER see GMC park lights for sale.
Coincidentally, I was at the junk yard Saturday and as I was walking past an old MTA passenger bus I happened to look over and see a marker light on the side of the bus that looked identical to the parking/turn signal light on my '53 except that the lens was amber. The housing itself is plastic, but you cant see that with the lens and ring on it. The guy told me I could have anything off the bus I wanted. If that is a stock part on an old passenger bus it might be a good place to look for replacements for our old GMCs. Of course that might be the only bus with those lights on it. | | | | | Joined: Feb 2006 Posts: 64 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 64 | You should also try.. http://www.oldgmctrucks.com/ forum. Alot guys are one both. I have two extra sets, to go along with 3 trucks. Found all on Epay... Lens I have new NOS bought under 1953 corvette as its the same lens. Not sure if the assembly is the same though. They do come up but you have to be looking often because they always sell. Good luck you will find them. keep it GMC... LOL Neal, | | | | | Joined: Feb 2006 Posts: 64 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 64 | Also get a hold of mothertrucker on here or the GMC forum under the same name, sure to have them...
| | | | | Joined: Jun 2012 Posts: 44 New Guy | | New Guy Joined: Jun 2012 Posts: 44 | Thanks to all,you have been a great help! | | | | | Joined: Apr 2001 Posts: 268 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 268 | I bought a whole truck for parts that had cherry parking lights.
