2 members (J Lucas, pauld), 123 guests, and 2 robots.
Topics128,183
Posts1,057,263
Members48,467
Junior Member
Junior Member
I've stripped out my heater for repair - and the wiring has been messed about.
There are 3 or 4 coloured wires going from the pull/twist heater switch to a block connector on the side of the heater ducting case, but one of the wires on this connector has been cut. Also, the fan has no wire leading to it (but still works if it has a live feed).
Is the connector block some kind of thermostat or motorised flap, or a resistor to give different fan speeds? Should a wire run from this connector block out to feed the fan itself?
I don't have a wiring diagram so any clues would be much appreciated
Regards Limey
Limey If the cut wire is brown and/or orange then I would say that is your wire that goes to the fan. The select switch gets 12volts power. Wire may be brn. or orange then it goes though this switch and comes out one of the other wires to the resistor block that cuts down the voltage the the fan. here is an example. Hope it helps blower diagram
Oehm
Nice train layout.
'67 GMC 3/4 292 4spd
Junior Member
Junior Member
Thanks Junior, I'll take a closer look
Junior Member
Junior Member
When I had the same situation in my 66 GMC I replaced the entire conrol circuit with a Bosch unit out of a late 70s Volvo. A vast improvement over stock [even if working perfectly] The only thing that made the entire job take more than 10 minutes was figuring out a mount for the big resistor. Now has FOUR real speeds in addition to OFF.
IF YOU DIDN'T TEST IT, IT DOESN'T WORK
