6 members (Greg '46, Hotrod Lincoln, Phak1, Otto Skorzeny, 2 invisible), 234 guests, and 2 robots.
Topics128,080
Posts1,056,063
Members48,433
#868346 07/21/2012 5:03 PM
Custom Title
Custom Title
Just wondering what everyone does for air filters an their dual carb setups. I have dual Carter YFs on my 235 and I want air cleaners that look cool, yet nostalgic. Any thoughts?
49 Chevy 3600
65 Chevy K10
48 International KB-1 Service Truck
55 Willys CJ5 - Chevy 331 powered
26 Model T Roadster Rat Rod
70 Tucker Sno-Cat 442-A
96 Dodge 3500 Cummins dually flatbed x-cab 4x4
06 Jeep Wrangler LJ rock crawler
If you can't fix it with a hammer, it's an electrical problem
http://www.speedwaymotors.com/Louvered-Style-Air-Cleaners,7201.html
Retired with to many Honeydo`s
Are you looking for nostalgic, as in original style: Jim Carter has original style oil-wetted wire-mesh air cleaners; or, find used oil mesh or oil bath cleaners.
If you are looking for nostalgic, as period correct "hot rod", many parts vendors have chrome/aluminum clearers/covers.
I have used original oil-mesh, original oil-bath, and both styles converted to use modern filter elements. I have also used a few styles of shiny after-market cleaners.
Use whatever appeals to your tastes.
No rule says you can't have multiple sets, either.
And change them depending on your mood or what type of event you're attending. For example, a scoop for a traditional hotrod look, a pair of converted stockers for a more "restored" look, or a pair of skulls for the October shows.
One thing I want to try is to make a scoop out of a rural newspaper box. I think it will work well with my Shiner Beer can coil cover.
regards,
Leon
< CLICK > My favorite dual carb air cleaner set up of all time. Greg_H's two original RPO #216D oil bath air cleaners on Rochesters mounted on an Offy manifold. Too cool!!
- Lonnie
My '54 3104
The sad news is that those carbs and air cleaners are now riding my parts shelf in favor of a better mannered set of Langdon's Carter/Weber carbs and his matching polished aluminum air cleaners. I think a little less power than the Rochesters but idle and starting are light years ahead of the old style carbs.
The downside of both setups as you see is the loss of the cab to inner fender braces. I think I will put them back on with some fit modifications. I have never seen that they appear to threaten any trouble but just want them back on.
My favorites have always been the late 30s to maybe 1950 or so standard truck air cleaner, not an oil bath. These are getting hard to find but just heard that the Filling Station has repros. These also will take an easy to find paper element.
1946 1/2-Ton Chevy
This is the standard oil-wetted air cleaner that Jim Carter sells in reproduction:
http://chevy.oldcarmanualproject.com/shop/1947truck/47ctsm0603.htm
