1 members (Bill Hanlon), 156 guests, and 0 robots.
Topics128,048
Posts1,055,540
Members48,425
#868404 07/21/2012 9:20 PM
Anyone have a picture of the way the #2
& #3 main caps are supposed to be installed on a 59 235? Been a long time since I pulled it apart and they aren't marked with an arrow. I'm sure they are marked but I don't remember the proper orientation. Any help?
CayoRV #868408 07/21/2012 9:29 PM
I may be wrong but the bearings have tangs that fit into the cap and the block. The two tangs go on the same side.
1951 1 Ton Completed
Yes the bearings do have tangs or notches on 1 end. I just wasn't sure if they were to be together or opposite. Anyone else know for sure before I screw up? (Its been know to happen before!)
CayoRV #868473 07/22/2012 7:32 AM
All the casting #s on top of the caps should read the same. So if you put on the last one or the first and the numbers read from the front than the number 2 and 3 should read from the front.
Pete
Pete52 #868474 07/22/2012 7:50 AM
OK, I think I follow that. If I'm standing in front of the motor on the stand all of the numbers should read either right to left or left to right, but not a combination of both.
CayoRV #868486 07/22/2012 8:44 AM
on all mine the numbers are facing towards the cam
#2 main cap has a "F" cast in it and when installed the "F" will be at the front of the cap. #3 main cap has a "R" cast in it. When installed the "R" will be to the rear of the cap.
My Blog
Thanks fella's. I'll be putting her back together tomorrow and I knew I could count on this site to keep me on the straight and narrow.
