Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
6 members (Wickedbass, 55shaker, lumbersawyer, Jaison, Donf, 1955 1 Series), 40 guests, and 2 robots.
Topics128,010
Posts1,055,298
Members48,419
#868334 07/21/2012 4:28 PM
I am having an issue with my fuel pump. It will fill just over half way but no more. I wont pump enough to keep the motor running. I switched pumps but the second one does the very same thing. Any suggestions?
1956 Chevy 3600
“Maynard”
In the DITY Gallery
More pictures on Flickr
Bart #868352 07/21/2012 5:29 PM
what 'fills half way'? the carb bowl? an inline filter? the glass bowl filter on the pump? ....
is the 2nd pump a new one or another old one?
has the carb been rebuilt? is the float set properly?
is your tank clean, or is there sludge in it that gets sucked against the tank outlet and stops/slows the flow?
have you checked any rubber sections of fuel line for deterioration, like maybe slightly leaking weather checks or collapsing internal layer?
lots of possibilities to investigate
Flxible #868412 07/21/2012 9:45 PM
The sediment bowl on the fuel pump only fills half way. I changed punps and the same thing happened. I unhooked the line and gas flows out of it just fine. I checked all of the clamps onn the line and they are all tight.
1956 Chevy 3600
“Maynard”
In the DITY Gallery
Bart #868419 07/21/2012 10:04 PM
the bowl and any inline filters never fill all the way, if the gas is flowing what ever is causing it to not keep running is elsewhere - if it's a fuel supply problem, more important is how much is in the carb
Flxible #868429 07/21/2012 10:42 PM
Thank you, I'll check the carb then.
1956 Chevy 3600
“Maynard”
In the DITY Gallery
Bart #870476 07/29/2012 9:33 PM
I took apart the carb this weekend. The valve was sticking closed. My truck is running just fine again. Thanks for your help.
1956 Chevy 3600
“Maynard”
In the DITY Gallery
