| | | Forums66 Topics128,034 Posts1,055,533 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#86813 06/18/2004 3:02 PM | Joined: May 2004 Posts: 43 Junior Member | | Junior Member Joined: May 2004 Posts: 43 | Any of you use a battery disconnect switch?
I would suppose this is easier than removing the terminal from the batt post each time I need to disconnect power.
Any particular brand or style to look for or to avoid?
Do you use it on the POS or NEG side?
Thanks!
Dave | | |
#86814 06/24/2004 4:01 AM | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Dave, I have used one for a few years. It's one of those cheap green ones you find a your local swap meet for a couple bucks. Mine is attached to the neg term.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
#86815 06/24/2004 5:31 PM | Joined: Aug 2000 Posts: 122 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 122 | The general rule of thumb I have seen is to always attach it to the Negative terminal. I bought mine from a local Parts Plus for about 7 bucks. It has a knob on top that you just twist to disconnect the cable. Works well.
Steve 55 1st Series 3/4 ton
#86816 06/26/2004 1:45 AM | Joined: Nov 2003 Posts: 113 Member | | Member Joined: Nov 2003 Posts: 113 | Just curious...are you doing this for anti-theft reasons or for ease in working on th eelectrical stuff?
Bruce (I love My Truck) Miller
1954 5 Window 3100 Chevy Pickup - Driver 1929 **** Model A Pickup - Restoration
#86817 06/26/2004 2:32 AM | Joined: Mar 2004 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2004 Posts: 96 | If you are doing it for security reasons...Caterpillar makes a good disconnect switch that has a key which opens/closes the circuit. Problem is they don't give it away...~$25-30.00 You could also try www.delcity.net they have good products and might sell a model like Cats'. However, if you are doing for servicing purposes, I would just go the route everyone else has listed. Good luck.
Whad you do?!?
Shane 1953 Chevrolet 3600
#86818 07/04/2004 3:14 AM | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Check out the latest Rod & Custom magazine. They have an article (more like an infomercial)on the installation of one. Made by Painless. Mine is Moroso and bolted to the valance under my seat. | | |
#86819 07/07/2004 10:42 AM | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | Shane 53 - that del city site is pretty neat.. all kinds of stuff on there. -W | | |
#86820 07/30/2004 3:49 AM | Joined: Mar 2004 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2004 Posts: 96 | Woogeroo, Yeah, they do have some cool stuff, prices are pretty decent and can be downright cheap if you buy in bulk. The nice thing is to get one of there free catalogs. They have lots of great pictures and it gives you a visual reference for some electrical parts even if you don't end of buying from them.
Whad you do?!?
#86821 07/30/2004 8:33 AM | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | I've got one on my '77 Vette, but I rarely use it. The instructions with it said to put it on the positive terminal, so that's where it is. | | |
#86822 08/11/2004 12:40 AM | Joined: May 2001 Posts: 71 Shop Shark | | Shop Shark Joined: May 2001 Posts: 71 | I think I have the ultimate battery disconnect  (used for security mainly). It's a Cole-hersee 24200 I think? solenoid. It's a latching solenoid, so you hit the pwr/gnd contacts momentarily and it switches on, hit it again and it switches off (using no power while not switching). You can trigger it w/ a remote, small switch somewhere, etc.
'53 Chevy truck 1/2 ton
#86823 08/11/2004 1:07 PM | Joined: Jan 2001 Posts: 1,422 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,422 | I have the standard twist off. Just yesterday I had a dead cell in my old battery and bought an Optima Red Top Gell Cell, heard lots about them thought I'd give them a try.
I asked the battery man (bought batt. from a dedicated battery-only store), "Do I have my disconnect on the correct pole?", he said, "Yes, the POSITIVE pole is the proper pole for a disconnect such as yours, you always want to keep the vehicle grounded."
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
#86824 08/16/2004 4:55 PM | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | In the Corvette, I use a keyed disconnect switch for security purposes, and since the glove box is right next to the battery box, the switch is hidden inside there and the red plastic key, which is attached to a removable keychain on my regular keys, has to be inserted and turned before I can start the car. I also have my electric fuel pump wired to an on/off toggle switch which is hidden under the ashtray.
On my Firebird, I have one of those battery post-mounted switches which you unscrew the knob to disconnect the battery and those work well too. For ease of installation and simple disconnection, they're probably the best. And yes, you mount them on the negative post.
I've always assumed that this is because electrons actually travel from negative to positive. Our system of labelling is actually backwards, from an engineering point of view.
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | |
