| | | Forums66 Topics128,111 Posts1,056,258 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2012 Posts: 19 New Guy | | New Guy Joined: Jul 2012 Posts: 19 | Whats everyone running in thier trucks for sending units on the "under bed" mounted tanks? Preferably 12v It seems the Suburban /panel version is no longer available. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | depending on the year, if it's a stock tank you should be able to use your old one to modify a pickup sender, for a different style replacement tank there's aftermarket 'universal' senders [which might work on an original tank too] .... and the voltage doesn't matter, it's resistance to look for > with a stock gauge you want a 30 ohm sender, not the more modern 90 ohms - should be able to get one from NAPA
Bill | | | | | Joined: Sep 2010 Posts: 1,707 back yard wrench turner | | back yard wrench turner Joined: Sep 2010 Posts: 1,707 | I ordered mine from American Classic Parts. sending unit Wayne1938 1-Ton Farm TruckStovebolt Gallery Forums1989 Silverado 1996 Mustang GT convertible When I die, I hope she doesn't sell everything for what I told her I paid for it! | | | | | Joined: Jul 2012 Posts: 19 New Guy | | New Guy Joined: Jul 2012 Posts: 19 | Thanks Red58 for the info
American Classic's phones are down, I went to ordered a 30ohn universal from Classic and they say that the universal one has no pick up tube?
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the tube is the primary difference of the in-cab and frame mount tank senders, the tube from your sender can be swapped over if it's not really rotten - if it's bad then you can fab up a tube to match the shape/length out of small tube for the one that Wayne linked above, even copper tube
Bill | | | | | Joined: Sep 2010 Posts: 1,707 back yard wrench turner | | back yard wrench turner Joined: Sep 2010 Posts: 1,707 | I used the drain hole in the corner of the tank for the gas feed. I also run an inline filter to trap any junk that might get into the tank. My tank is also new. Wayne1938 1-Ton Farm TruckStovebolt Gallery Forums1989 Silverado 1996 Mustang GT convertible When I die, I hope she doesn't sell everything for what I told her I paid for it! | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Bot mine from Jegs and It came with the sender. | | | | | Joined: Dec 2006 Posts: 97 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 97 | (deleted off topic question)
(This question needs to be asked in it's own thread in HiPo shop.
Cletis)
