8 members (Jethro in Va, 3B, Wingnut68, moparguy, Peggy M, Possum, 1955 1 Series, dt235sd),
65
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,197 Posts1,057,400 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 54 'Bolter | | 'Bolter Joined: Sep 2007 Posts: 54 | Thought I crawl under my 66 and try and back off the rear shoes. The rear brakes are dragging real bad and i'd like to pull the drums off. I can't move the adjusters at all to loosen things up. I think I'm in trouble....any suggestions? Thanks
..."some gave all, KIA"...
| | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Surely someone has something that can help this guy. | | | | | Joined: Nov 2005 Posts: 6,101 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,101 | Hy 57NAPCO, adjusters can be a real bear at times, have you tried a punch and hammer through the adjuster hole, sometimes the shock of hammer blows will break them free. You could also try using a puller on the hub, pull against the end of the axle tube, but protect the end of the tube. Pulling in this way will definately ruin something, but short of torching an access hole to deal with the stuck adjusters, sometimes it is the only way to get things apart. One other thing you might try is, unbolt the wheel cylinders from the backing plate, and knock them into the brake drum, this may allow the shoes to collapse enough to allow the drum to come off, hope that helps, and good luck! | | | | | Joined: Sep 2007 Posts: 54 'Bolter | | 'Bolter Joined: Sep 2007 Posts: 54 | Excellent, I'm on it and I'll let ya know
| | | | | Joined: Mar 2011 Posts: 39 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2011 Posts: 39 | I had the same problem with my 66 with a t150 rear you have to insert a small screw driver into the hole to move the adjuster lever away from the adjuster star and while holding it away use a brake spoon to the loosen the adjuster. | | | | | Joined: Sep 2007 Posts: 54 'Bolter | | 'Bolter Joined: Sep 2007 Posts: 54 | The light comes on for me !!
When looking thru the slot I could swear I saw a peice of metal to the back of the adjustment star. I was pushing it around with a screwdriver and wondering what it was?
You guys are the best !!!!
