0 members (), 155 guests, and 4 robots.
Topics128,110
Posts1,056,241
Members48,437
Whats everyone running in thier trucks for sending units on the "under bed" mounted tanks? Preferably 12v
It seems the Suburban /panel version is no longer available.
depending on the year, if it's a stock tank you should be able to use your old one to modify a pickup sender, for a different style replacement tank there's aftermarket 'universal' senders [which might work on an original tank too] .... and the voltage doesn't matter, it's resistance to look for > with a stock gauge you want a 30 ohm sender, not the more modern 90 ohms - should be able to get one from NAPA
back yard wrench turner
I ordered mine from American Classic Parts.
sending unit
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
Thanks Red58 for the info
American Classic's phones are down, I went to ordered a 30ohn universal from Classic and they say that the universal one has no pick up tube?
the tube is the primary difference of the in-cab and frame mount tank senders, the tube from your sender can be swapped over if it's not really rotten - if it's bad then you can fab up a tube to match the shape/length out of small tube for the one that Wayne linked above, even copper tube
I used the drain hole in the corner of the tank for the gas feed. I also run an inline filter to trap any junk that might get into the tank. My tank is also new.
Wayne
1989 Silverado
Bot mine from Jegs and It came with the sender.
(deleted off topic question)
(This question needs to be asked in it's own thread in HiPo shop.
Cletis)
Never take a sleeping pill and a laxative at the time.[/i]
1955 Chevy 3100
More pix on Photobucket
