| | | Forums66 Topics128,194 Posts1,057,263 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2011 Posts: 28 New Guy | | New Guy Joined: Jul 2011 Posts: 28 | Hey guys, have a 59' Apache 3100 with the 235. One of the four bolts that hold the carb together has been MIA since I picked up the truck. I'm about to rebuild the carb and have not been able to locate a replacement bolt locally at any automotive or hardware stores and have no idea where to order a new one.
Can anyone send me in the correct direction on getting a replacement?
-Troy
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Check fastnal Slotted fillister Head screw ....link.... A good hardware store might carry them | | | | | Joined: Jul 2011 Posts: 71 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2011 Posts: 71 | Is it a Rochester or Carter carb? Post a pic, I might have one I can send you.
Vince | | | | | Joined: Jul 2011 Posts: 28 New Guy | | New Guy Joined: Jul 2011 Posts: 28 | Is it a Rochester or Carter carb? Post a pic, I might have one I can send you.
Vince It's a Rochester. I can post a pic tomorrow afternoon.
-Troy
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | It must be a model B. Coach or I can send you one. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | The Rochester Bs were upgraded somewhere around 1952 and the size of those screws changed. | | | | | Joined: Jul 2011 Posts: 28 New Guy | | New Guy Joined: Jul 2011 Posts: 28 | Sorry for the delay, here is the pics of the bolt. Also needing the brass fitting for the fuel pump. I took that to hardware stores as well and no one could get me one that cuts at an angle. I accidently threw my old one away. In the pic is the straight one (that goes up to the carb). I need to know what the one is called / size of the one that connects to the tank fuel lines. Bolt pic Both pieces
-Troy
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy dvious, The screw is a 10/32" X 3/4" fillister head I believe, you didn't specify which angle of fitting you required, so here are the Weatherhead p/ns for the fittings straight is 202X5X4 45 degree is 325X5X4 90 degree is 402X5X4, hope that helps. | | | | | Joined: Jul 2011 Posts: 28 New Guy | | New Guy Joined: Jul 2011 Posts: 28 | Hate to bump this again but I can't find that fitting by the part number. I need the 45 degree. Can anyone give me the specs on it? I think I'm getting close though: http://www.fastenal.com/web/products/detail.ex?sku=440079-131280
-Troy
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The fitting for the feul pump is most likey a male pipe to female inverted flare, you'll need to go to the local auto parts store to find one, rather than a hardware store. The numbers that 3B posted are for Napa, but any parts stroe should be able to cross reference them if you don't have a Napa store locally.
Bill Burmeister | | |
