2 members (Hotrod Lincoln, Barry Martak), 164 guests, and 1 robot.
Topics128,189
Posts1,057,337
Members48,469
#867719 07/18/2012 9:46 PM
Hey guys, have a 59' Apache 3100 with the 235. One of the four bolts that hold the carb together has been MIA since I picked up the truck. I'm about to rebuild the carb and have not been able to locate a replacement bolt locally at any automotive or hardware stores and have no idea where to order a new one.
Can anyone send me in the correct direction on getting a replacement?
-Troy
Check fastnal
Slotted fillister Head screw
....link....
A good hardware store might carry them
Is it a Rochester or Carter carb? Post a pic, I might have one I can send you.
Vince
Vince
It's a Rochester. I can post a pic tomorrow afternoon.
-Troy
Riding in the Passing Lane
It must be a model B. Coach or I can send you one.
1972 Chevy c10 Cheyenne Super
The Rochester Bs were upgraded somewhere around 1952 and the size of those screws changed.
1951 1 Ton Completed
Sorry for the delay, here is the pics of the bolt. Also needing the brass fitting for the fuel pump. I took that to hardware stores as well and no one could get me one that cuts at an angle. I accidently threw my old one away. In the pic is the straight one (that goes up to the carb). I need to know what the one is called / size of the one that connects to the tank fuel lines.
Bolt pic
Both pieces
-Troy
3B Offline
Hy dvious, The screw is a 10/32" X 3/4" fillister head I believe, you didn't specify which angle of fitting you required, so here are the Weatherhead p/ns for the fittings
straight is 202X5X4
45 degree is 325X5X4
90 degree is 402X5X4, hope that helps.
Hate to bump this again but I can't find that fitting by the part number. I need the 45 degree. Can anyone give me the specs on it?
I think I'm getting close though: http://www.fastenal.com/web/products/detail.ex?sku=440079-131280
-Troy
The fitting for the feul pump is most likey a male pipe to female inverted flare, you'll need to go to the local auto parts store to find one, rather than a hardware store. The numbers that 3B posted are for Napa, but any parts stroe should be able to cross reference them if you don't have a Napa store locally.
Bill Burmeister
1 Offline
Try this for the fuel pump fitting:
http://www.chicagocorvette.net/category_view.php?cat_id=1101
and for the screws:
http://www.classicchevy.com
and search for part # 34-145 or 34-146
Joe D.
