0 members (),
108
Mod | | | Forums66 Topics128,035 Posts1,055,560 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2012 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2012 Posts: 59 | I have an EZ-Wire kit I bought some time ago. It is a gm truck kit. I have almost a good portion of the truck wired up and now I am working on the light switch that can adjust the lighting on the dash. I have almost everything wired up but can't find the wire that goes from the light switch to the gauges. I have gauge power but that is all I have found. Does anyone know if gauge power goes to the dash terminal on the light switch? The manual says that the dash light wire is brown. I looked at every wire and can't seem to locate it. Thanks, Bert | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | year? what manual? the factory manual doesn't show any brown wire on the light circuits - brown should be the color for the gas gauge I believe - most years have a tab at the front of the switch that is one end of the coiled resistor wire and that runs the dash lights [that's the "dash terminal"], which get power thru the main supply to the switch - the "D" terminal on the switch is the Dome light, the dash light wires are all gray and usually they're all hooked together with a soldered or crimped joint, you probably didn't get the actual dash lights with the harness, but that "bundle" needs to get hooked to that rheostat on the front of the switch
Bill | | | | | Joined: Jul 2012 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2012 Posts: 59 | The kit is an EZ-wire kit so there is no years. The manual is an EZ-wire manual. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | What year truck?
Are you using a stock switch? | | | | | Joined: Jul 2012 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2012 Posts: 59 | 1953 chevy truck. I replaced all the switches because I am going to 12 volt. The only thing I'm leaving 6 volt is the starter. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | odd that they wouldn't use the original color codes that have been standardized for many years .... compare the factory wire diagram and you should be able to see what wires go where, the dash lights are pretty simple
Bill | | | | | Joined: Jul 2012 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2012 Posts: 59 | I know where the wires go but I can't find the light wire for the gauges. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | I know where the wires go but I can't find the light wire for the gauges. Are you refering to the instrument lights? You should have a harness with 5 sockets. I have this site booked-marked, Looks like this guy used an EZ kit ...link... ...EZ Kit... Good Luck | | |
