2 members (1955 1 Series, Hotrod Lincoln), 148 guests, and 2 robots.
Topics128,189
Posts1,057,337
Members48,469
drive
Hi all,
I have a 1952 GMC 454-30. I am not sure if the suspension is standard or a special order.
Can't find any number on it. I.D. info plate on glove box door only states number of springs and axle manufacturer (Eaton).
The suspension is not in my service manual. Not that I could find.
Trying to find rubber bushings for torsion bars.
Thanx,
Dance like no one is watching,
Sing like no one is listening,
Love like you've never been hurt.
1948 GMC FC101 1/2t Pickup w/270 and SM420
1948 GMC FC253 1t Factory 80"x9' Flatbed Dually
1948 Chevy COE 2 Ton 8'x15' Flatbed
1950 GMC 354-24 2 Ton 8'X12' Flatbed w/Dump Hoist
1953 GMC 454-30 3 Ton 8'x14' Flatbed w/Dump Hoist
1953 GMC 454-30 3 Ton Cab and Chassis
1942 Clarkator 6 MILL-44 Heavy Aircraft Tug
1942 Ford (9N) Moto Tug with 1/2 yard Loader
1947 Oliver OC3 HG-42 Tract-Crawler Bull Dozier w/6' Blade
That torsion bar setup, is not standard equipment. Would have been special order.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
3B Offline
Hy GMCPic, could you post a picture of your suspension? Your truck probably has rear suspension with a radius rod to control torque, could that be the "torsion bar" you're looking for bushings for?
sounds about right, I will get pictures tomorrow
For a minor description...:
Leaf springs have shackles at both ends, rods connect in line with the frame under the forward spring mount and connect to the bottom on axle spring clamp underside of axle. Ends of rods are offset to connect under frame and under the axle.
It reminds me of an early Hendricks setup but I do not believe it is Hendricks.
GMCpic, I call those torque arms and not all 450s had them. It was an option. Original spec sheet calls them radius rods.
GMCpic, check page 351 and 352 of your maintenence manual. It shows a picture on page 352.
Pictures of Suspension are here:
http://s1253.photobucket.com/albums/hh594/GMCPic/
Thanx
