Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
4 members (1955 1 Series, Dennys28, baldeagle, tclederman), 44 guests, and 2 robots.
Topics128,004
Posts1,055,265
Members48,418
#8668 05/20/2003 7:19 PM
hey guys need to find out the settings for my points thanks
#8669 05/20/2003 7:31 PM
.016" to .019" Make sure mechanical and vacuum advance is working properly, and to put some lube on the point's rubbing block. Use a ballast resistor if running 12 V. Set plugs .035"-.040"
good luck
chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
#8670 05/20/2003 7:36 PM
THANKS CHIPHEAD I set them at .16 and she spits and spudders it's been awhile since it's been started should I maybe install new points?
#8671 05/20/2003 9:09 PM
File points, check gap & check timing. Do the normal checks of carb & ignition. Maybe check for good spark at a plug. Shouldn't take too much to wake her up if nothing seriously wrong.
chip
#8672 05/20/2003 10:06 PM
Point gap will directly affect timing.
Paint & Body Shop moderator
#8673 05/21/2003 1:27 AM
I think minor cleanup will solve problem it ran great when I parked her
#8674 05/21/2003 9:07 PM
" .019"for new breaker; .016" for a used breaker".
If it hasn't been run for a while, the fuel might have gone funky....
Frank McMullen
1941 Chevy dump truck
1949 GMC 100 pick-up
1954 Chevy 3600 pick-up
1955.1 4400 dump truck
1941 De Soto & other MoPars
1928 Model A F**D Special Coupe
