0 members (),
128
0
Mod | | | Forums66 Topics128,035 Posts1,055,560 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#86683 07/26/2002 9:49 AM | Joined: Jul 2002 Posts: 18 Junior Member | | Junior Member Joined: Jul 2002 Posts: 18 | i was doing some thinking (OUCH) use two 6V batteries in parallel to charge them, and a DPDT switch wired between them to change parallel/series to get 12V when i need it. how could i do this with just diodes to isolate them is there a dc dc power supply that doesn't cost $300 has anyone made one from old microwave or TV parts i'm serious thx
" the first rule of the intelligent tinkerer is to save all the parts" aldo leopold
#86684 07/26/2002 8:39 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Have you considered converting to a 12 volt system? Install a 12 volt alternator, replace all light bulbs, add resistors for the heater fan, gas gauge, and a new battery is a lot less than $300. And you still use the 6 volt starter, so your engine cranks twice as fast.
Fred 52 3600 69 C-10
#86685 07/26/2002 11:41 PM | Joined: Aug 2000 Posts: 197 Member | | Member Joined: Aug 2000 Posts: 197 | Honestly, dump the 6 volt system. It just isn't as good and it isn't compatable with anything else. I pondered using a series/parallel switch for a 12/24 volt system but found out that they are expensive and not very reliable.
Jason
#86686 07/27/2002 1:12 AM | Joined: Jul 2000 Posts: 504 Member | | Member Joined: Jul 2000 Posts: 504 | I am still a 6 volt guy. Geez, anybody can make a motor crank and start quickly with 12 volts. The trick is to do the same job with half the juice..
Bill M 53 GMC Hydra-Matic
Home Page http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
#86687 07/27/2002 8:25 PM | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | I am not sure "juice" equals "volts". I would think juice equals amps which are actually higher in a 6 volt system?
54 3100 with 235 62 flatbed dump C60 with 261
#86688 07/28/2002 3:01 AM | Joined: Mar 2001 Posts: 316 Member | | Member Joined: Mar 2001 Posts: 316 | Yes, and that's why the heavier gauge wiring (and windings in the starter and generator), for the amps. Six volt batteries don't live as long as twelve volt models do (IMHO). Had my generator "re-wound" for 12 volts and a new regulator, bulbs and battery. Even when the battery is half dead, it will still start easily..............also got rid of the positive ground that GMC was so fond of.............you just have to switch the wires on the ammeter so it will read correctly and put a resistor in the hot wire to the gas guage so it won't burn up  .
*** GMC ***
#86689 08/08/2002 2:58 PM | Joined: Jan 2000 Posts: 125 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 125 | I look at it this way. Power to start your truck is calculated as volts time amps. A 12 volt battery with 500 cold cranking amps has twice the power a 6 volt battery with the same cold cranking amperage rating does. I run 12 volts in my Chevy but think I will keep my GMC 6. I can understand some people want the oringal sound of the 6 volt starter and horn.
Grant 1950 Chevy 3100 1952 GMC 150 (In Pieces) 1968 Chevy K20 1966 Shovelhead 1978 BMW 100S
#86690 08/09/2002 8:59 PM | Joined: Jan 2001 Posts: 198 Member | | Member Joined: Jan 2001 Posts: 198 | Radio Shack (archer) use to sell 6v to 12 v Inverter's at one point, that would put out 5a at 12v enought power to work a standard radio. Problem was they will only convert 6v -ground. keep you eyes open at a flea market or on e-bay, found one at sally ann one day for $3 working. | | |
