4 members (Nick in Manitou, TUTS 59, Alaska54, Cosmo), 54 guests, and 2 robots.
Topics128,029
Posts1,055,417
Members48,422
#86683 07/26/2002 9:49 AM
Junior Member
Junior Member
i was doing some thinking (OUCH)
use two 6V batteries in parallel to charge them, and a DPDT switch wired between them to change parallel/series to get 12V when i need it.
how could i do this with just diodes to isolate them
is there a dc dc power supply that doesn't cost $300
has anyone made one from old microwave or TV parts
i'm serious
thx
" the first rule of the intelligent tinkerer is to save all the parts"
aldo leopold
#86684 07/26/2002 8:39 PM
Have you considered converting to a 12 volt system? Install a 12 volt alternator, replace all light bulbs, add resistors for the heater fan, gas gauge, and a new battery is a lot less than $300.
And you still use the 6 volt starter, so your engine cranks twice as fast.
Fred
52 3600
69 C-10
#86685 07/26/2002 11:41 PM
Honestly, dump the 6 volt system. It just isn't as good and it isn't compatable with anything else. I pondered using a series/parallel switch for a 12/24 volt system but found out that they are expensive and not very reliable.
Jason
#86686 07/27/2002 1:12 AM
I am still a 6 volt guy. Geez, anybody can make a motor crank and start quickly with 12 volts. The trick is to do the same job with half the juice..
Bill M
53 GMC Hydra-Matic
Home Page
http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
#86687 07/27/2002 8:25 PM
I am not sure "juice" equals "volts". I would think juice equals amps which are actually higher in a 6 volt system?
54 3100 with 235
62 flatbed dump C60 with 261
#86688 07/28/2002 3:01 AM
Yes, and that's why the heavier gauge wiring (and windings in the starter and generator), for the amps.
Six volt batteries don't live as long as twelve volt models do (IMHO). Had my generator "re-wound" for 12 volts and a new regulator, bulbs and battery. Even when the battery is half dead, it will still start easily..............also got rid of the positive ground that GMC was so fond of.............you just have to switch the wires on the ammeter so it will read correctly and put a resistor in the hot wire to the gas guage so it won't burn up smile .
*** GMC ***
#86689 08/08/2002 2:58 PM
I look at it this way. Power to start your truck is calculated as volts time amps. A 12 volt battery with 500 cold cranking amps has twice the power a 6 volt battery with the same cold cranking amperage rating does.
I run 12 volts in my Chevy but think I will keep my GMC 6. I can understand some people want the oringal sound of the 6 volt starter and horn.
Grant
1950 Chevy 3100
1952 GMC 150 (In Pieces)
1968 Chevy K20
1966 Shovelhead
1978 BMW 100S
#86690 08/09/2002 8:59 PM
Radio Shack (archer) use to sell 6v to 12 v Inverter's at one point, that would put out 5a at 12v enought power to work a standard radio. Problem was they will only convert 6v -ground. keep you eyes open at a flea market or on e-bay, found one at sally ann one day for $3 working.
