2 members (jay d, Gdads51), 75 guests, and 2 robots.
Topics128,265
Posts1,058,360
Members48,485
#86660 10/31/2003 11:01 PM
I'm in the process of refurbishing the instrument panels in my 1949 3600. I'm having trouble determining how the speedometer needle is removed. Can anyone offer some advice.
Thanks!
#86661 10/31/2003 11:29 PM
It is a friction fit, but be careful because it is easy to break off the shaft coming out of the speedometer. Soak it with Kroil or PB Blaster before you try to remove it.
Paint & Body Shop moderator
Apprentice
Apprentice
Be careful! I snapped mine off first time. The needle fits over the tapered or cone-shaped pin. If you torque it, it will break. Try putting some penetrating oil on first with a Q-tip or something. After it sits for a bit try to work it off. Go slow; new ones are $160!
Good luck,
Dave '47 3800
Don't read the directions, that'd be too easy.
I found that rotating it gently counter clockwise against the stop, while pulling gently, did the trick for me. I practiced this on a couple of spare units and it worked every time. However, a lot of old needles are very brittle and they will break off in your hand. That is why they sell them along with the decals.
1951 1 Ton Completed
