5 members (3800GUY, Shardean, Stovebolt48, Peggy M, Hotrod Lincoln), 79 guests, and 6 robots.
Topics128,021
Posts1,055,349
Members48,420
#866475 07/12/2012 6:50 PM
I've got alot of pin holes and one larger hole on the drivers side.
I see ebay has patch panels by goodmark for about $100. Anybody used these? and can give a review?
Goodmark patch panels are the standard, as good as you'll find, may require a bit of fudging for your application .... they're the line commonly carried by the auto parts stores, check your locals for prices and save the freight, if Goodmark makes it NAPA should have it listed
That is a good idea, I'll check with napa.
I might just cut out the piece from the patch panel that I need.
