| | | Forums66 Topics128,014 Posts1,055,331 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2012 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2012 Posts: 60 | I've got alot of pin holes and one larger hole on the drivers side.
I see ebay has patch panels by goodmark for about $100. Anybody used these? and can give a review?
Thanks | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Goodmark patch panels are the standard, as good as you'll find, may require a bit of fudging for your application .... they're the line commonly carried by the auto parts stores, check your locals for prices and save the freight, if Goodmark makes it NAPA should have it listed
Bill | | | | | Joined: Mar 2012 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2012 Posts: 60 | That is a good idea, I'll check with napa. I might just cut out the piece from the patch panel that I need.
