3 members (1955 1 Series, Bill Hanlon, treegrower), 305 guests, and 3 robots.
Topics128,152
Posts1,057,012
Members48,460
Just received the carrier kit I ordered from Jim Carter. The long portion fits in the sloped track as it should. But I'm wondering if it's too long for my truck. In the upward position, it extends to the back of the truck, directly below the tailgate.
I also have no idea what the shorter bracket is for. Would anyone happen to have a photo of a complete installed spare tire carrier?
I love this website, but I have to say, it's got the worst search function I've ever come across. Perhaps it's me?
Thanks for your help as I figure out my first Stovebolt rig!
Consider it a function in developing patience.
BTW you will get more help in the forums by posting pics of what you need. My first thought was of a side tire carrier. Good luck.
~Jim
Denny's site has pictures from the assembly manual of different styles of underbed carriers. He has a pic of Woodys old truck also
1949 didnt have a side mount originally
The search function did come up with a post with pictures
Great pictures. Quick question....does the smaller C bracket bolt to the wheel, or to the bed rail? Obviously, bolting to both would make the spare a somewhat permanent part of the truck!
It's held in place with the two nuts to the carrier
http://www.pbase.com/dennygraham/image/121819674
Not to the bed
Only the j hook bolt holds the carrier up
Ok...to make sure I'm clear - The wheel bolts to the C bracket (carrier). The only attachment points to the truck are the J hook on one end and the pivot on the long bracket at the other end. Talk about low-tech. Guess you need a wrench on-board to remove the bolts from the spare in the event it's needed for its intended purpose.
My valence doesn't have a hole for the J hook. Perhaps it was replaced with the wrong valence at some point over the years? Unless advised otherwise, I'll drill one.
PREVIOUS POST ON THIS TOPIC
USE THIS SEARCH ENGINE AT THE TOP RIGHT OF THIS PAGE, NOT THE ONE IN THE MIDDLE TOOL BAR
If you dont have a lug wrench you wont be able to remove your flat. same wrench should be able to remove the nuts for the carrier.
there is another style carrier
http://www.pbase.com/dennygraham/image/121820558
your truck could have used that style above
If you do drill the hole be sure to reinforce it well.
~Jim
Ok...
Possibly the previous owner changed the bed and it came from a newer truck
