8 members (JW51, Woodcmiami, Gdads51, dt235sd, MickeyP, HandyAndy, k2handyman, 1 invisible),
58
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,699 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 261 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 261 | Ok All, not sure why it is not posting i'll try again. I need the lower patch panels for my AD 1/2ton. Is there a prefered vendor for sheet metal or do all vendors buy the sheet metal from the same source? Are the panels a good match in sheet metal gauge thickness and shape?
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | hey rc - try hitting the 'edit' button on your post and see if you can get some text in there .... if that doesn't work, try rebooting your computer, seems to work for some others
Bill | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | rc,
Did you type in information that did not show up, or, did you cut and paste iinformation that did not show up?
What type of computer/operating-system and what browser?
This is being experienced by more and more people. Letting the tech people know about what you are using and what you are doing might help figure this problem out.
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I emailed the thread in the 'bus about this issue to Paul but no reply yet. If I remember right one poster mentioned they had this issue with Safari but not with FireFox. Dang gremlins anyway.
| | | | | Joined: Nov 2008 Posts: 261 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 261 | I need the lower patch panels for my AD ½ ton. Is there a preferred vendor for sheet metal or do all vendors buy the sheet metal from the same source? Are the panels a good match in sheet metal gauge and shape?
Thanks!
| | | | | Joined: Nov 2008 Posts: 261 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 261 | I guess the problem was that I copied and pasted my message text. I am using explorer. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I have the same problem, doing the same thing in Safari on an iPad.
If Paul, or the moderator of his forum (or you), edits your blank message, I bet the text shows up in the edit box.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Well, this is helpful information. At least as far a speculation/diagnostics is concerned. I'll try this in Firefox tomorrow.
What computer/operating-system were you using?
| | | | | Joined: Nov 2008 Posts: 261 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 261 | Does anyone have any suggestion on this topic? There is a big difference in pricing amoung vendors for the cab patch panels. I do not mind paying more money for a better fitting panel if there is a difference amoung them. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Which patch panels? Try typing in the part number(s) and give the vendor's name.
| | | | | Joined: Nov 2008 Posts: 261 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 261 | I am looking for the lower rear cab corner patch panels. Most of the vendors seem to carry them. | | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | Not the patch panel you are looking for, but I found that the patch panels need tweaking no mater where you buy them. Don't expect them to be perfect matches. I think I bought from 3 different vendors and I wouldn't say that one was better than the other. My work was all on the inner and outer cowls on a 48 cab. Just cut out as little as possible, but get to the good metal for sure. Take your time and make sure it fits before you stitch in the welds. A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Mar 2010 Posts: 78 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 78 | one caution on cutting out as little as possible, you need to cut all the way out past rust pitted metal inside or out. If not welding in new will be more difficult and that is the last thing you need. I purchased rear corners and front cowl inner and outer from Jim Carter door panels from chev of the 40s. I looked for american quality and ask questions. Still had to do work on all to get perfect fit.
1951 chevy 3100 short bed frame off resto.
