4 members (Oswald, rfs56trk, baldeagle, jasrking), 49 guests, and 1 robot.
Topics128,014
Posts1,055,332
Members48,419
#865643 07/09/2012 8:28 PM
I picked up the 53 panel today and trying to get some info on the motor
here is # on dizy pad f630AE
door jam# 20kp-1 5150
i need to clean motor to get casting #s
thanks
for any info
josh 53 panel
sinistar #865655 07/09/2012 8:55 PM
Since you show both upper-case and lower-case letters, can we assume that the "f" in f630AE is a lower-case "f"?
here is a pic of # on the pad
thanks
josh
Is it possible this is the number?
year id Pad casting#
60 Chev Trk F0361A 3769716
Now that I see the photo..... nevermind..
Give me ambiguity
or give me something else
CASO #865674 07/09/2012 9:38 PM
Head and block casting codes, and head and block date casting codes, might help.
found the head # pic
will clean some more to find block#s
thanks
josh
sinistar #865711 07/09/2012 10:52 PM
It's a '58-'60 Passenger 235, Flint plant on June 30, originally with a manual trans. It could possibly be up to a '62, but my guide cuts off with Passenger car engine codes at '60. There is a casting date near the starter that will help peg the year.
Bill Burmeister
f630AE
Factory
Month & Day
A indicates Passenger
AE in 1958 is Regular with heavy duty clutch
http://chevy.oldcarmanualproject.com/chevyresto/58003.htm
-Tom
1950 Chevy 3100 w/ 1956 235
Oilrag #866185 07/11/2012 2:21 PM
I have a 1955 2nd series 235 with this number on the pad behind the distibutor FI0I7B, if you click on the link at my signature you can see a picture. What year engine do I have?
Larry
deere36 #866267 07/11/2012 8:20 PM
It's a '57-'62 Passenger engine, built at Flint on Oct. 17, originally used with a Powerglide/Turboglide. You'll need to get the date code near the starter to get the year.
Bill Burmeister
Does this mean it has hydraulic lifters? What will the date code look like, I tried to look there and the starter is almost covering up something but it is hard to see.
Larry
deere36 #866276 07/11/2012 8:57 PM
All 235 passenger car engines from 1956 onwards had hydraulic lifters.
Was a Turboglide transmission used with a 235?
I can't answer that it would seem possible in the later years that a turbo could have been used. I am still stuck on the fact that I have a 1955 truck with a later engine that came with hydraulic lifters, when I got the truck it would barely run and after major tune up still had dead miss on number 4 cylinder. I got it hot per instructions and removed valve cover to adjust valves and number four intake rocker was off the valve so I adjusted it for solid lifters and it runs like new now, so do I readjust for hydraulics or how can I verify lifter type?
Larry
tclederman #866298 07/11/2012 10:19 PM
After further research, no, they were not. When I looked the code up, it only listed it as being used with "Automatic Transmission", but did not specify type. I've rechecked and cross referenced my guides, there are specific listing and codes for the V8 with the Turboglide, and no listings for 235 with any automatic other than Powerglide in Passenger.
Bill Burmeister
LONGBOX55 #866302 07/11/2012 10:30 PM
Thanks for all your help, I am going to try to get the numbers above the starter tomorrow to verify the year on mine.
Larry
deere36 #866306 07/11/2012 11:04 PM
Bill,
I think that someone posted information that confirmed that a Powerglide was used on a truck sometime between 60-62. It was not clear what lifters were used.
tclederman #866309 07/11/2012 11:08 PM
Yes, it was. The code for that engine would be JB. I beleive they were solid lifter, though, as the shop manual doesn't show a listing for a hydrualic cam in the 235, only for the V8s.
Bill Burmeister
Longbox,
The only legible number is J 11 right above the starter, is this a good date code? The other code is FI0I7B on the pad behind the distributor. If you look at the picture of the pad the only numerics are the zero and the seven, did they use an I for a 1?
Larry
deere36 #866407 07/12/2012 2:03 PM
Maybe J 1 1 means October 1 1961 ?
F1017B in 1961 would mean:
F = Flint, MI assembly plant
10 = October
17 = 17th
B = Regular engine (235) in a passenger car equipped with a Powerglide transmission
I and 1, O and 0 often were often interchanged.
That sounds about right to me, though an engine cast and assembled in October of '61 would more likely be from a '62 model year truck.
Bill Burmeister
Longbox55 & tclederman,
I am understanding I have a 61 or 62 passenger car engine that came with a powerglide? So that would mean it had hydraulic lifters unless someone changed them?
Larry
deere36 #866499 07/12/2012 7:59 PM
Larry
Yes
TurboGlide was not an option until 57'. I don't recall any I-6's with them and certainly never worked on one in my time with a dealership. They were lousy transmissions and had no scoot even with a hot V8. Much more like a DynaFlow than anything else.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
