Brrrr
place holder
3 members (1954gmc9314, Ponchogl, 1 invisible), 102 guests, and 4 robots.
Topics128,272
Posts1,058,419
Members48,485
#86618 09/03/2004 12:21 PM
I have found a decent replacement material for the rubber clutch plate in the tuner mechanism. If anyone is interested, I will explain further.
1951 1 Ton Completed
#86619 09/08/2004 3:11 PM
I'm interested, please reply.
Winona
1949 3100 5 Window Deluxe Cab
#86620 09/09/2004 1:53 AM
Thanks for asking! I didn't want to "waste bandwidth" !
The radios of this era use a clutch mechanism which disengages when a station button is pushed, to allow the tuner to move position. The clutch has a metal diaphragm on each side and a thin rubber membrane disc in the middle. The rubber membrane distorts over time with bumps appearing and it results in the clutch slipping, to the point that the tuning doesn't work through the knob. It is difficult to find a suitable replacement for the membrane but I managed to do so.
I cut apart a pair of latex kitchen gloves which are rubber on the outside and some kind of smooth material on the inside. I took a piece and glued two inside surfaces together with contact cement, creating a new membrane with rubber on both sides and having almost identical physical characteristics as the original material.
#86621 09/09/2004 4:35 AM
Great! I never would have thought of that!
Winona
#86622 09/09/2004 8:03 PM
49er,
just another little hint. On my first attempt at putting contact cement on the glove material, it bubbled up out of shape. On the second successful attempt, I taped the material to a peice of wood, applied the glue and when it was tacky, I removed the tape and stuck it together.
