| | | Forums66 Topics128,164 Posts1,056,966 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 639 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 639 | The plan is to put an '87 T5 behind my 235.
Trust me, I've spent the last three hours reading about this swap before asking.
I see some people use spacer plates (from Buffalo and other venders) but assumed that was just the easier (albeit more expensive) route, but have read that bolting the gearbox to the bellhouseing without the proper spacer plate does not hold the input shaft true enough and can cause damage to the input shaft and trans bearing.
What are your thoughts/experience? | | | | | Joined: Jul 2011 Posts: 71 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2011 Posts: 71 | I have no idea, but I am very interested in this I'm about to swap as well. Thank you for asking! | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Ive done 3 of them & a freind has done 2 & we didn't use a spacer. If you modify the trans. acording to the tech tips It works fine. The main thing is to grind the splines on the input shaft so the disc will slide back about 1/2 in. If you have a good pilot bushing in the crank you will support the shaft as well as with a spacer. The only advantage of the spacer is you could change trans. without going through the modifications, but you still would have to drill out the mounting holes. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jun 2011 Posts: 420 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 420 | i just finished my 88 t-5 swap into my 46 1/2 ton and i used an adapter from bendtsens and didnt have to cut anything, the only drilling you have to do is drill out the holes to 1/2 on the trans because they are metric,(case is aluminum, so it will drill easily) and the bolts are standard thread, dont forget that you have to change the clutch disc to match the spline on the T-5 and also if using the the original shifter like i did, you need to straighten it,(i stuck mine in a press and straightened it no problem), P.S. if you go to transmissionadapters.com they will even set you up with the right clutch disc for you're trans,thats what I did and everything slid right together with no problems,if you have any questions, i might be able to help you | | | | | Joined: Dec 2011 Posts: 32 New Guy | | New Guy Joined: Dec 2011 Posts: 32 | Since we are on the subject can any of you tell me what length speedometer cable to use with the T5, I understand the stock one is too short. My truck 55 w/235 has no cable at all on the stock transmission so I have nothing to compare.
Larry | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | if you build a T-5 hybrid (V8 Camaro front half, S-10 rear half), you do not need to trim the shaft or cut splines.
| | | | | Joined: Mar 2006 Posts: 113 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 113 | I'm in the process of building a "decision tree" on a T5 swap.
Last Friday I took my '37 to the transmission guy who rebuilt my 3sp last year (I only got ~250 miles before 2nd gear locked out!) and he offered to set me up with an automatic trans instead. (way to stand behind your product!).
So I'm back to square one. Do I find someone else and rebuild what is clearly an old and problematic transmission? Do I try to find another (took me eighteen months last time!)? Do I switch to an auto (I would prefer to keep it a manual shift)? If I go T5 I'll have to change rear axles and that opens a huge can of worms!
So just like twotone I've been studying like crazy.
~rocker~
Everything is different now...
