8 members (cmayna, Gray_Ghost, Donf, Otto Skorzeny, Gdads51, Jon G, Forty9, Shade Baby), 104 guests, and 0 robots.
Topics128,118
Posts1,056,307
Members48,439
#865945 07/10/2012 8:33 PM
I
I Offline
May buy a G506. From research it looks like the Diffs are 6.51, TC is 1.94, but I can't find anything on the tranny. I've seen it called a GM Corporate Spur-gear or Sliding-Gear transmission.
Does anyone know for sure what the tranny and ratios are, in particular the granny gear ratio?
Also, seller said he thought that the 235 in military trucks had a pressurized oil system instead of just a splash type. Anybody know four sure?
What year truck/trans are we talking about?
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
I
I Offline
Sorry. It's a 42.
I
I Offline
Dug up this site with old repair manuals. It's probably old news to you guys though.
http://chevy.oldcarmanualproject.com/military/1942/index.htm
Anyway, it doesn't identify the tranny but does give the ratios as follows:
1st 7.06
2nd 3.48
3rd 1.71
4th 1.00
Rev 6.98
I believe the later SM420 has a 7.02 granny
If it is the original 235 that came in the truck then it is a babbit bearing, splash oil motor. The only way it would be full pressure would be if someone pulled the original motor and put a later one in. The cckw or "Duece and a Half" was built by GMC and the motors in those trucks (270 cu in) were of a more modern design the Chevrolet 506's used basicly a bigger version of the 216.
-Mike-
1945 Chevrolet G 506 1.5 Ton Military 4X4
1967 Jeep Cj5 with 283 SBC
I
I Offline
Found some more ratios for the Diffs and TC on this website and another.
http://www.stovebolt.com/gallery/lampman_greg_1942.html
This Stovebolt article reports a diff ratio of 6.67 and TC of 1.94 and granny of 7.06. 91:1 -- Woohoo!
He is replacing the orig tranny with a NV 4500 5-sp with ratios of 6.04, 5.6, 1.67, 1, 0.73.
The 1942 military 4x2 manual linked in a post earlier in this thread shows a Diff ratio of 6.17 with an optional 5.43 diff. Of course this manual is for the 4x2.
I
I Offline
Sleeve
Thanks for the info on the 235. Seller says that someone told him it might be a newer 235, a 1952, but I thought the pressurized 235 didn't come out until 54.
Yep, wish it was a Jimmy. I've got a 51
GMC 1-ton with a 302.
If I buy the 42 it'll probably never see another 100 miles. Will just pull stumps on my mountain property in Silverton, so a 235 will be OK.
Originally Posted by izzenhood
Sleeve
In four wheel low these trucks are unstoppable.....your stumps wont stand a chance. :>)
