1 members (Oswald), 243 guests, and 2 robots.
Topics128,162
Posts1,056,942
Members48,458
Tonight I reinstalled the transmission and quickly connected the brake and clutch pedal assemblies.
I had taken a ton of photos of disassembly, but now that I've got it back together, something isn't right to me.
There are two springs which assist in returning the brake and clutch pedals to their non depressed states. The brake pedal stops when the plunger reaches the back of the master cylinder.
What stops the the clutch pedal? Right now the lower half of the pedal is coming to rest against my freshly painted cross member!!! (and taking paint off with it!)
<Pedal resting on crossmember>
<From top>
Does it rest against the the cab when the cab is there??
Mark
someone with an assembly manual will be able to say, but I would expect there to be a hard rubber piece that slips over both pedal arms to cushion them from the floor board [the way 55-59's are], you don't want the brake piston to be slamming against the end of the MC if you're foot slips off, and you don't want to listen to the clutch rattling against the floor wink
Bill - I totally agree with you, which is why I ask... It's Section 5, Sheet 2 of my assembly manual and shows no rubber, or any sort of stop.
My cross member shows no sign of wear where it's hitting now - so I wondered if its an adjustment issue.
Regardless, anyone able to shed some light?
Mark
Here is a pic I have
...pic...
...pic2...
...pic3...
I mistakenly added a bumper to the brake arm. My truck originally had only one bumper on the clutch arm. I found nothing on the brake arm.
Thanks DADS50,
So the cab is what stops it. Where did you pick those bumpers up?
Mark
I picked up the bumper at classic parts
...link...
I re-used the original on the clutch and added A new one to brake
The new one didn't fit well and I had to remove material to get it to fit the arm
Your right. Once you get the cab on I think you'll find the rod won't travel far enough to hit the crossmember.
see FL116, it's the one for the TF years
wicked - thanks guys!
