Brrrr
place holder
5 members (Wayne67vert, Gdads51, jay d, Bill Hanlon, Otto Skorzeny), 140 guests, and 3 robots.
Topics128,274
Posts1,058,425
Members48,485
Why do the inlets of '53 brake wheel cylinders face foward if the brake lines end couplings are actually behind the axle ? To me, one would almost want to switch the left from the right so that the inlets face towards the rear of the truck pointing more towards the brake line end couplings.
Maybe I'm reading things wrong. If the box say front left wheel cylinder, this is driver's side yes?
Craig
yes its as you are sitting in your truck left and right
Sorry,
Front brakes.
Craig
I'm guessing you have the brakes apart just now .
Try fitting the wheel cyls up on the wrong sides , and the flexible hoses (no fluid) then go full steering lock each way and see what contortions the hose goes thru , then look at the way it works when fitted up correctly .
Let us know what you find . smile
I have seen those front wheel cylinders installed both ways, some with the hose facing front, others with the hose facing rear.
However, there is more than one picture in the GMC service manual that shows the passenger side ( right side ) with the hose facing to the rear.. That is the way I installed mine when I replaced the cylinders..
Bill M
53 GMC Hydra-Matic
Home Page
http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
rat Offline
I also have a '53 and when I replaced my wheel cylinders the inlets faced back, which seems normal to me. Thats the direction they faced when I took them off.
'52 Chevy 5 window, it ran when I parked it
'53 Chevy 5 window, running the streets with me.
'55 Massey-Ferguson, tearing up the dirt
'89 Harley FXSTS, suicide clutch
'92 Harley FLSTC, equal time with the '89
Just a reminder, I am putting a '53 front assembly on my '50. The wheel cylinder inlets on the '50 face straight towards the engine.
When I got the '53 front assembly I noted that both cylinders faced towards the front so I could assume that the ends of the brake lines on a '53+ are located near or in front of the axle ?
Since the ends of my brake lines are behind, shouldn't I just swap the cylinders (put left on right side, etc) so they are somewhat facing their respected lines?
Yes Dusty, I will look into switching them. The only difficult issue is that this '53 assembly is on my workshop table, not under my truck, but I will still have a good idea if this will work.
Craig
You may find the casting numbers on the wheel cylinders may be the same, just drilled different, take a look as to where the body end of the flex hose is mounted, if it's at the back then the bleed screw goes toward the front
