3 members (dt235sd, cmayna, Hotrod Lincoln), 102 guests, and 2 robots.
Topics128,142
Posts1,056,490
Members48,442
#865517 07/09/2012 1:17 PM
Z
Z Offline
I am working on getting my 41 half ton titled and plates issued. I live in WI and the forms require the gross weight of the truck. I am assuming it is 4,500 lbs. Is this correct? I have no way of actually having it weighed.
Have a look here......http:/chevy.oldcarmanualproject.com/chevyresto/4114htm
1940 Chevy KC 1/2-Ton
Zippy, should not be close to that if it's a stock half-ton. My '40 KC is listed in one book I borrowed as 2840 lbs. Doesn't say if it's gross weight, but I think so. Yours should be well under 3500.
1940 Chevy 1/2 ton pickup "KC"
A day without sunshine is like, well, ..... dark!
My VIN plate is stamped 4600 lbs. It's a 1941 1/2 ton.
