8 members (pauld, lumbersawyer, Gdads51, frogfarmer, J Lucas, carbking, Charles in CA, 1 invisible),
99
7
Mod | | | Forums66 Topics128,264 Posts1,058,358 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2010 Posts: 171 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 171 | Looking for hubcaps for a 54 with 16" original wheels. Don't know if I want original caps or "moons". The question is what size do I ask for? Do I take a measurment from the outside of the clips or the raised area of the wheel, between the clips and the lugs.
....David
| | | | | Joined: Mar 2011 Posts: 457 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 457 | I wouldn't worry about size, rather the application. Stock wheel caps are readily available. Try Jim Carter, LMC, etc. Most older wheels were made to standard sizes and use similar hubcaps...my '40 Chevy will fit my '40 Ford!
1940 Chevy 1/2 ton pickup "KC" A day without sunshine is like, well, ..... dark! | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Great thing about these 6 lug wheels/caps is that all the caps will interchange as long as it was held on with clips. and all 6 lug rims will interchange with car or trucks. Ran a nice set of 57 pickup rims on my 47 coupe in the past with the 47 caps. | | |
