4 members (Nick in Manitou, Gdads51, Bill Hanlon, FAST55), 75 guests, and 2 robots.
Topics128,138
Posts1,056,751
Members48,454
So my brake lights do not shut off after the brake pedal is depressed. They will however shut off if I go underneath the truck and move the switch back farther. It's as if the brake pedal arm does not go back enough to disengage the switch. I looked in both the Assembly and Shop manuals and they say nothing about shimming the switch. I also saw something called a Brake Pedal Bumper that looks like it would fit on the arm of the Brake Pedal. Is this Bumper responsible for making contact with the Brake Light Switch to shut the brakes lights off when the pedal is depressed?
I had to use a bumper on my AD for this problem as well. Also the switches seem to go bad in a couple years or so? Something internal (cheap) I think they fail to contact after a while. You can bend the arm as well (carefully).
the rubber bumper should not contact the brake sw arm, but there should be one to keep the metal pedal arm from banging against the bottom of the floor board - and coming up too high inside
as said, you should just bend the switch arm carefully until it's working correctly, once you have the pedal working properly
My '59 did that and it was just the switch had died. Simple replacement fixed it, but you may have some other things going on......
1940 Chevy 1/2 ton pickup "KC"
A day without sunshine is like, well, ..... dark!
Riding in the Passing Lane
Sometimes you need to put a piece of rubber hose over the stem.
1972 Chevy c10 Cheyenne Super
Thanks for all the replies. Picking up new Brake/Clutch pedal bumpers tomorrow. I'll try to bend the actuator bar, if I feel I'm going to beak it I've got some real thick tubing I can install. Thanks again
I don't think you are going to bend that bracket without destroying the switch.
