| | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 253 Shop Shark | | Shop Shark Joined: Dec 2010 Posts: 253 | With the split ring Budd wheels there is always some saftey concern with mounting new rubber but I was wondering if anyone has ever welded the ring on perminently and then levered the tires over it the same way you would with a one piece wheel?
I'm thinking there is probably a lot of good reasons not to but I'm not thinking of any of them at the moment. Is this a bad idea?
All input and "are you crazy" comments welcome.
-Mike-
1945 Chevrolet G 506 1.5 Ton Military 4X4 1967 Jeep Cj5 with 283 SBC
| | | | | Joined: Nov 2006 Posts: 173 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 173 | I asked my tire shop this question and they responded that tires for these wheels have a rather significant steel band/ring in them that prevents this. I'm sure someone with some first hand knowledge will pipe up soon. Scott
1947, 1950, & 1952 Chevrolet 1/2 ton 1952 GMC 450 series Cab Over Engine 1946 Chevrolet 2 Ton
| | | | | Joined: Feb 2004 Posts: 29,751 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,751 | It would be impossible to get the tire onto the wheel with the ring welded on. On single-piece rims, there has to be a drop center section to let the tire bead drop into that area while it is being pried over the rim. The center of a split ring wheel is straight- - - -no dropped center, and no way to get the tire on without removing one bead ring. Drop-center rims have to be larger diameter to clear the brake drums. A 22.5" tubeless tire on a drop-center rim is the same overall height as a straight-wheel 20" tire. The extra 2.5" of bead diameter in the tire helps it slide over the rim and into the dropped center section. Jerry
| | | | | Joined: Dec 2010 Posts: 253 Shop Shark | | Shop Shark Joined: Dec 2010 Posts: 253 | Yep that makes sense. I've changed my own motorcycle tires for years taking advantage of that very drop center! I knew I must be missing something here and that was it, the flat center on the Budd wheels, plain as day but I didn't make the connection!
-Mike-
