3 members (Guitplayer, Patina 54, Steelonsteel), 42 guests, and 2 robots.
Topics128,035
Posts1,055,441
Members48,422
#865096 07/08/2012 12:39 AM
With the split ring Budd wheels there is always some saftey concern with mounting new rubber but I was wondering if anyone has ever welded the ring on perminently and then levered the tires over it the same way you would with a one piece wheel?
I'm thinking there is probably a lot of good reasons not to but I'm not thinking of any of them at the moment. Is this a bad idea?
All input and "are you crazy" comments welcome.
-Mike-
1945 Chevrolet G 506 1.5 Ton Military 4X4
1967 Jeep Cj5 with 283 SBC
I asked my tire shop this question and they responded that tires for these wheels have a rather significant steel band/ring in them that prevents this. I'm sure someone with some first hand knowledge will pipe up soon.
Scott
1947, 1950, & 1952 Chevrolet 1/2 ton
1952 GMC 450 series Cab Over Engine
1946 Chevrolet 2 Ton
It would be impossible to get the tire onto the wheel with the ring welded on. On single-piece rims, there has to be a drop center section to let the tire bead drop into that area while it is being pried over the rim. The center of a split ring wheel is straight- - - -no dropped center, and no way to get the tire on without removing one bead ring. Drop-center rims have to be larger diameter to clear the brake drums. A 22.5" tubeless tire on a drop-center rim is the same overall height as a straight-wheel 20" tire. The extra 2.5" of bead diameter in the tire helps it slide over the rim and into the dropped center section.
Yep that makes sense. I've changed my own motorcycle tires for years taking advantage of that very drop center! I knew I must be missing something here and that was it, the flat center on the Budd wheels, plain as day but I didn't make the connection!
-Mike-
