8 members (3B, cshades, cmayna, Gdads51, moparguy, MickeyP, JW51, 1 invisible),
104
Mod | | | Forums66 Topics128,064 Posts1,055,861 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2007 Posts: 460 Shop Shark | | Shop Shark Joined: Mar 2007 Posts: 460 | Well yeah... I sure as hell don't own one!  | | | | | Joined: Mar 2007 Posts: 460 Shop Shark | | Shop Shark Joined: Mar 2007 Posts: 460 | I guess it is possible the thermostat is faulty or sticking. New one costs less than $ 10.00 / 10 minutes to re & re. Might be worth a shot ? I'll take her for a cruise once I get all her fluids up to where they should be and see what she does... if the problem continues I'll come back to it and change it if need be... I'm really not that worried about the trip there when it is cooler in the morning... it's the return trip with packed highways when it will be the hottest time of the day that I find a little scary... maybe I'll see if a neighbour can come in and let Gadget out for a pee in the afternoon... then we won't have to rush out of there till dinnertime and I might even be able to follow someone back through yarrow... hate to not know where I am two years in a row!  | | | | | Joined: Sep 2011 Posts: 305 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 305 | I am heading out around Noon, we'll be a bit late. I've got the 3.55 gears so the Highway is fine. If you guys go through Abby at 11:00, that'll be a bit early for me. Thanks for asking but I"d like to make the grand entrance after everyone is there.... | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Trev....if u need a hand changing the stat or tightening the fan belt, bring it over to my place on Saturday. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Trev, you're checking everything else, why not the belt tension, it's not rocket science? Just a note to everyone, if your car starts to overheat in traffic, slip it into neutral, and raise the r.p.m. slightly, this increases the rate of coolant flow through the rad, and the engine fan speed as well. A stuck thermostat will just let the engine get hotter and hotter, the fact that the engine does cool back down says the thermostat is functioning. We could put a 160 degree thermostat in it and give you 20 degrees more wiggle room. | | | | | Joined: Mar 2007 Posts: 460 Shop Shark | | Shop Shark Joined: Mar 2007 Posts: 460 | I'll see what the tension on the belt is when I top up the coolant later on Bobb... the only thing is I have no idea what the tension is supposed to be so I'd just be guessing...
Last night I topped up tranny fluid (which leaks when the car sits too long) and engine oil was fine so as soon as I check and top up the rad she should be good to go for a drive before dusk... It won't be the same as the 30 degrees we're supposed to get Sunday but hopefully I get an idea how hot she is gonna get anyway...
As for the 160 degree thermostat, sounds like a good idea for this old beast to keep her a bit cooler... I'll see how she acts when I have her out tonight and go from there.
Are you going to be around this evening by chance, Bruce? | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Trev........I think we are around tonight....give me a call if you are heading this way. Bobb has a good point about the T Stat. If you want to pick up a 160* we can pop it in. ( Make sure it comes with a gasket ) Fan belt play should be around 1/2" on its' longest span | | | | | Joined: Mar 2007 Posts: 460 Shop Shark | | Shop Shark Joined: Mar 2007 Posts: 460 | No worries Bruce... we'll try for tomorrow instead IF the car needs it... rather wait till I can get to Lordco and get one than take a chance on Ukrainian Tire and rushing around tonight... I'll give you a buzz tomorrow if need be... thanks  | | | | | Joined: Mar 2007 Posts: 460 Shop Shark | | Shop Shark Joined: Mar 2007 Posts: 460 | Hey guys... just wanted to make sure we had all we would need for tomorrow... Here's what we have so far... Bobb: Chili,Nanaimo bars coffee Bruce & Tammy: 2 Pies Paul: coke, juice, bottled water, smokies and buns Mikey: potato salad and a mixed greens salad Trev: Triple Chocolate Brownies No word from Dave or Boyd what they're bringing yet... anybody else bringing anything they want to add to this list? It's looking a bit sparse so I think we'll also pick up a fruit or meat platter just to be safe... better to have too much food than not enough, right?  Oh and Dave, are you planning on picking up the picnic table in the morning on the way out? Let me know... | | | | | Joined: Sep 2011 Posts: 305 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 305 | My kids are baking Chocolate Chip cookies as we speak. I could bring Watermelon?? A far as meat, we were just bringing a few dogs but can bring anything. John | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Boyd & Sue are still away in Alberta. Trev / Dave....whats your plan as far as " convoy ". If I don't hear back from you guys, we are planning on leaving our place around 10:00 See everyone tomorrow | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Gonna meet up with Mike & Suzanne at the Safeway lot- 208 & Fraser Hwy at around 10:15 | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | HY guys, if anyone needs driving instructions please PM me. | | | | | Joined: Mar 2007 Posts: 863 Shop Shark | | Shop Shark Joined: Mar 2007 Posts: 863 | I will have to go shopping at that time then.... better late than never...  | | | | | Joined: Mar 2007 Posts: 460 Shop Shark | | Shop Shark Joined: Mar 2007 Posts: 460 | Dave are you coming for the picnic table on the way or not? If so feel free to come by anytime after 9:45 (which should give you plenty of time to still make the rendezvous with Mike and Bruce etc at Safeway at 10:15)... As for us, I have made the decision to leave the '55 at home... it's gonna be sweltering hot and since I am more than likely going to sell the '55 in the near future or do a swap plus cash deal for a hot rod, no sense putting hard miles on the '55 if I don't have to... We'll be meeting up with you guys out at Bobb's and taking Celine's honda to get there... Oh one last thing, in addition to the triple chocolate brownies we're also bringing a large fruit platter for everyone and a huge bag of Munchies... See everyone at Bobb's tomorrow... remember to bring the bug spray... I'm hearing the mosquitoes are hungry out there!  | | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | Oh yeah.... bug spray. Bobb asked me to bring some pics and the dang printer is printing RED!. I'll just bring the laptop and leave it on slide show.
I guess everyone will be at Bobb's truck-o-rama between 11 and 12?
A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Mar 2007 Posts: 460 Shop Shark | | Shop Shark Joined: Mar 2007 Posts: 460 | If the guys are leaving Langley around 10:15, probably closer to 11:30-45, Paul... they're taking the slow route... Hope to see everyone out there!  | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | If we are not " escorting " the '55 we will jump on the freeway at Abbotsford / should be at Bobbs around 11:15 or so.... | | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | I hope you kids all have fun at the BBQ! I'll not be there, but I do get to ride on a steam train, so that's a small consolation!
Paul, I'll get my act together and mail you Angel's toque, and your shifter clock. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Guys, thank you everyone who came out to my pickanick (Alvin you missed a good one), I hope you all had a good time. I love to see the beautiful iron parked on my lawn, and to see everyone enjoying themselves (I hope). Thanks for the food and the company, and thanks to Paul for cooking, and to Dave for the assist with the table repairs. I hope everyone had a safe and uneventful drive home. Sorry Mike and Suzanne were under the weather and couldn't make it, hope you guys feel better soon. Thanks again everyone! | | | | | Joined: Sep 2011 Posts: 305 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 305 | Had a great time, finally putting faces to names, great group. Thanks for the tour Bobb, very interesting. Hope to meet up with you all again.
Oh and Bobb, if that tranny is a '54, what do you want for it? Don't worry, I checked with my wife first!! | | | | | Joined: Mar 2007 Posts: 460 Shop Shark | | Shop Shark Joined: Mar 2007 Posts: 460 | Thanks for hosting, Bobb... this is becoming quite a tradition we have going and every year it seems to grow... Too bad that Mikey and Suzanne couldn't make it... Anyway, nice to see everyone again... hopefully if the weather stays nice I can host a get together at my place next month and finally have everyone over... Thanks again...  | | | | | Joined: Sep 2006 Posts: 139 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 139 | Hey I spent the afternoon in the blazing sun replacing the water pump on our daily ride( the 95 Cheyenne p/u). yesterday i replaced the rad and lower rad hose and i thought i had it beat but after borrowing my neighbours cooling system pressure tester this morning i could then see the coolant whizzing out of the relief hole.
sorry we had to cancel but i didn't want to take the chance with the h20 pump and a 3 hr round trip as i still had a large puddle under the truck again this morning.
That's the only reason we didn't make it!
guess what we had for dinner? lots of salad!
cheers to all and to all a good night.
mike out!
1947 Studebaker M15 on 76 GMC one ton dually chassis with 454 4 spd 1953 Chevrolet 1/2 ton p/u 1957 Oldsmobile 88 2dr hardtop 1959 B130 International one ton dually | | | | | Joined: Mar 2007 Posts: 460 Shop Shark | | Shop Shark Joined: Mar 2007 Posts: 460 | You have the worst luck on picnic days... the fan belt 2 years ago, the fan belt last year and now this... I'm thinking we should choose a different day next year...  Sorry y'all couldn't make it!  | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Adding my thanks to Bobb & Bernie for hosting. Always good to see everyone again. Really liked Kevins' '54 Buick hardtop - pretty rare beast ! | | | | | Joined: Mar 2007 Posts: 863 Shop Shark | | Shop Shark Joined: Mar 2007 Posts: 863 | Nice to see the usual Suspects.... Thanks to Bobb and Bernie for hosting... Some traditions we need to break....Mikey knows what I'm talking about...  | | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | Mike's luck with cars and BC Bolter gatherings is just bad. But if you look at the bright side, it is good as a diagnostic tool. A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy guys I'm glad everyone that came had a good time, Mikey sorry your truck let you down, I was told you were under the weather, glad it was just the truck. We have aquired a nice red two compartment cooler, and a salad fork any claimers? Paul I have your tongs. | | | | | Joined: Nov 2009 Posts: 84 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 84 | Thanks Bobb. Glad I could make it even though it was very short for my wife and I. I learned more on the tour so I'll have to keep coming back until you are out of information. Good to meet a bunch of you... again. Clay | | | | | Joined: Feb 2008 Posts: 202 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 202 | Hi, Bobb, I had a good time, enjoyed the tour but at the end the heat got to me, but on the plus side the 49 was not bothered by the heat at all. I drove back to Port Coquitlam at 50 to 60 MPH (Patricks 3:55 gears) no problem, Temp very steady at 180, Oil pressure steady at 13-14 PSI ( Note: I am trying Mercruiser 25/40 oil this year).
Keep the 216's running. 1949 1/2 ton model #1314 (US 3104) Brian
