| | | Forums66 Topics128,036 Posts1,055,461 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 253 Shop Shark | | Shop Shark Joined: Dec 2010 Posts: 253 | I'm trying to help out a friend who has a coolant leak at the back of the motor in his late 50's chevy pick up that has a small block V8 probably a 283. I'm thinking there is a rotten freeze plug in the back that is leaking but I'm much more of a staight six guy than SB v8's so can anybody tell me where the plug or plugs would be on the back of that motor or for that matter another possible source of leaking coolant originateing from the back?
-Mike-
1945 Chevrolet G 506 1.5 Ton Military 4X4 1967 Jeep Cj5 with 283 SBC
| | | | | Joined: Feb 2004 Posts: 29,751 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,751 | Two possibilities- - - -yes, there are freeze plugs behind the flywheel, one on each side of a small block V-8, and there's also a coolant passage at the extreme back end of the intake manifold on each side where it meets the cylinder head. A seep leak there can run down the back of the block and look like it's coming from the bellhousing area. Leaks don't run uphill- - - -coolant or oil- - - -always look for the highest wet spot! Jerry
| | | | | Joined: Dec 2010 Posts: 253 Shop Shark | | Shop Shark Joined: Dec 2010 Posts: 253 | Thanks, I'll pass that on!
