Brrrr
1 members (baldeagle), 139 guests, and 1 robot.
Topics128,274
Posts1,058,432
Members48,489
#864690 07/06/2012 10:34 AM
I am cleaning up a '53 cab to replace the wrecked one on the Blue Funk.
On the toe pan, at the place where the right fender and left where the parking brake bracket attach, I removed strips of some sort of black substance similar to asphalt.
For future reference when I put things back together again, I need to know: What are these strips?
Thanks.
Dave
The Blue Funk: a '51 3100 4 OTF with a '57 235
More pix on Photobucket
Quote
Any chance you can post a link to a photo of the location(s) you are referring to?
sounds to me like something that would hold the asbestos insulation in place, my 55 has the same stuff on the toe board and it's a real pain to clean off.
1949 Dodge Coronet
1955 2nd Chevy 4400 1.5 ton
1955 2nd Chevy 3100 1/2 ton
1957 Chevy 5400 LCF 2 ton
1966 Dodge D100 Sweptline
1968 Chevy P20 stepvan
1969 GMC LWB pickup
1972 GMC Sprint
1974 CP30 shorty bus
I just set up a booth and borrowed a sand blaster from a friend to deal with asphalt in my fender wells. Why? Because paint will not stick to it. Not cheap paint like rustoleum or spendy 2 part epoxy primer I've tried both. It will look ok untill you hit it with a pressure washer or comppressed air and then it will lift like a page of paper. I've tried grinding, sanding, carb cleaner and reducer but that s*#t gets deep into the metal and won't let go. The sand blaster is doing the job great and is at least as fast as grinding and sanding and I won't have to worry about paint failure inside the fenders anymore. Just a warning as you start to dig it out that covering it up with paint won't make you happy down the road
Give me ambiguity
or give me something else
Anti squeak ?
http://www.chevsofthe40s.com/images_product/large/3701900C.jpg
The replacements are paper. Not like original
The longer pieces are for inner to outer fenders
Originally Posted by DADS50
Anti squeak ?
Ding,ding we have a winner!
More pix on Flickr.
...in the event the strips shown is not what your looking for you can use strips of roofing felt. I suggest the #30 weight rather than the 15lb felt.
If it is the asphalt/tar material that held the sound deadener to my toeboard, I had to use tar remover, paint remover, and kerosene to get it off.
Thanks for the replys and the link.
I had no trouble removing the strips, only using a putty knife and then wire brushing off what remained.
Alvin's suggestion, of using roofing felt, sounds like an interesting tact to take- roofing felt on a toe pan!
Thanks again, Guys!
Dave
From Denny's web site
...link...
He also made his own out of 30#
Excellent! Outstanding!
Thanks Gus!
You are the "One Stop Shop" for Parking Brake Information!
Dave
