Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
5 members (baldeagle, Wally / Montana, EchoBravoSierra, JW51, 1 invisible), 60 guests, and 2 robots.
Topics128,006
Posts1,055,267
Members48,418
#864632 07/06/2012 2:23 AM
Due to the wiring by the PO of my 66 C10, I had to order a new engine harness. I ordered one from Classic for a V8. I have electronic ignition - so does the hot that would normally go to the coil, now go direct to the distributor?
Thank you
Tim
timmc #864674 07/06/2012 4:33 AM
Yes but that wire probably needs to be replaced with a larger one.
Thank you sir
timmc #865253 07/08/2012 3:45 PM
Riding in the Passing Lane
If it is a factory HEI unit you need to bypass the resistance in the system & use 12 gauge wire like Cletis says. If it is a conversion electronic ign. you need to follow the manu. directions.
1972 Chevy c10 Cheyenne Super
