6 members (Uncles51, Peggy M, dwreills, JW51, Millenimech, Chip O), 41 guests, and 1 robot.
Topics128,035
Posts1,055,446
Members48,422
#864269 07/04/2012 5:09 PM
The Heat Riser Spring on my 292 is broken, and the only place I have located one is at the "The Truck Shop", out here in LA. The book only lists 60 - 65. Does anyone know if there is a difference between 65 and 66?
Don't know if there is a difference. Jim Carter box at left has had them in the past. part number ME188 fits 1937-65.
My riser was broke on my 235 so I took one off a 250 and put it on my 235. works great. I had to grind the weld to get it out of the 250. Then grind it to fit the 235, minimal. I stuffed the shaft in with care to get alignment right and tack welded it in place. I checked it with a propane torch. It moved when heated. Easy as standing a shoestring on end. But couldn't find all the parts any where.
