5 members (Millenimech, Stewart2, Gib70, Hotrod Lincoln, 1 invisible), 129 guests, and 5 robots.
Topics128,077
Posts1,056,032
Members48,433
#864301 07/04/2012 7:19 PM
It wasn't pumping. Took it apart, cleaned, and reassembled. Put Marvel Mystery oil in inlet side. Pushed on lever and oil sucked in, but oozed back out. Loosened all 6 screws a little and it worked normal when I repeated the process. Tightened screws and it doesn't work. Loosened screws again and it works. When I took the pump loose from the engine, the lever didn't have full throw and when I pushed it in, it took several seconds for the lever to return back out. Is one of those little check valves messed up? Which one? Jim
1953 Chevy 3100 3 window
1997 VW Rialta Motorhome
2011 Fusion
Jimbar #864315 07/04/2012 8:32 PM
Ex Hall Monitor
Ex Hall Monitor
You can buy rebuild kits that have the valves in it. Just rebuild it. That's a lot simpler than trying to figure out which one is bad. Besides if one is bad the other likely is as well.
Tiny #864328 07/04/2012 9:59 PM
I agree with Tiny, get a rebuild kit for it. The diaphragm is probably bad, the spring should be replaced. And the inside of it should be cleaned out properly. Unless you really want to keep the original pump you can probably go to NAPA and buy a replacement cheaper than messing with yours. Don
